I'm sure you can bring in the car for motorsport use (regardless of age) but that would still require a lot of money and you can't drive it on a daily basis.
www.cams.com.au
All the info and rules and regs you'll need can be found here.
A couple of my mates have already got their exemptions they said they were easy as to get. all you do is write a letter stating why you have to drive the performance car (mum and dads cars are both at work, they are auto and they cant drive manual, and say you cant get to work any other way cos they are at work). My mate said that, added a letter from his boss for good measure saying that he needed to be at work within 20 minutes of being called or his job would be at risk. That was it, sent it in, it was back within a week with his exemption.
Funny thing is, with this exemption in place it wouldnt have stopped the blue 34 GTR crash that started all this in the first place...
How can you say that this is because of that particular accident?
He was not the owner of the car..
Edited by sl!m
exemptions are if you need the car for work or if the car is the only car in the household
i think if you get an exemption for the work reason, you will only be able to drive it during work hours or to/front work.. e.g it'll be dodgy if they caught you happy lapping on george street on a fri/sat night lolz
if you got your licence before july 11th and moved up to your greens, you will still be able to drive your car... its only those that lose their licence that will not be able to
Yeah i know it was his parents car. and you can get an exemption to drive your parents car , you would just have to think of a good reaso. like what if your parents only own a v8 or turbo car? And you cant afford a car of your own at the moment
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
