  • Replies 96
The difference is Ash, Patrick is looking for cars which look good and aren't Pintaras :D
Patrick, I'm noone to decide which cars you choose, but I would go with the following:
LeeWah R33 GTR (Midnight Purple) (If not sold)
Goglo R33 GTR (Midnight Purple) (If not sold)
Bass Junky R34 GTT (Silver)
And your 4th car is up to you.
get some class up ya.
not these dime a dozen cars
Hello All
From the recent replies the cars which seem the most appealing are:
LeeWah R33 GTR (midnight purple)
yug_r34 R34 GTR (white)
gtiarr R33 GTR (silver)
Goglo R33 GTR (purple)
Bass Junky R34 GTT (silver)
I have not received a reply from Goglo so I do not know if he is willing to help out.
So many cars to choose from, wish i had more formals so I could sit in each of your cars :D
The above list is just a draft and can change at any time depending on the availability of the person and their car. So please do not hesitate to post.
Thank you all
Regards
Patrick
The difference is Ash, Patrick is looking for cars which look good and aren't Pintaras  :)
Edited by Rekin
Ah k, thanks for clearing it up.
As both R33's (Jamezilla & LeeWah) are purple it would look much nicer. Lets hope they are both available ^^,
Thanks all
- Patrick
Patrick,
Jamezilla (James) ownes Golgo (Purple ppl eater....... sorry i mean R33 GTR)
how bout i go hire out a lambo 4 the night and drive use around in that? :) nothing beats a lambo
To hire a lambo costs $400 and I don’t think it can sit 8 people :P
Thank you ylwgtr2 for your participation, you will be definitely considered in the top 4 cars ;)
It's just so damn hard to choose only four cars....
Also another group claims to be arriving in a Hummer Limo. Guess the competition for the best rides is heating up. Luckily I have no chance at losing :D
The formal will be around 6pm - 7ish pm. No official time has been announced, I hope this opens up some doors for other drivers *looks towards Snowman* :(
Thanks all.
- Patrick
Ah... try adding a '0' to your Lamborghini hire cost, and I didn't think there was a Hummer Limo in Melb??
Anyway - this is a school formal, not the Oscars. Every year some kid claims to be arriving in a Countach or a helicopter or a horse or riding Falco the stupid luck-dragon from Neverending Story... and every year that same kid ends up spewing in some stranger's yard after drinking wipeout and coke and getting slapped for trying to feel-up his date.
Having a fleet of Slylines trumps any lies from your buddies. Let's just keep it at that.
And 7pm is past Snowy's bed-time, so don't get your hopes up.
BTW: Having a turd of a day so a bit grumpy. And for the record, my mum dropped me and 'date' off at my formal in the red Peugeot station wagon. Class all the way baby.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
