Hey i have been a member for a while but not posted much but now since i have a skyline i have some q's!! Thanks in advance...
How much do the stock injectors flow?
Is running 15psi boost safe...
What is the viscous lsd like for drift...
zaffa
https://www.sau.com.au/forums/topic/85357-1997-ecr-33-questions/
zaffa
Viscous LSD, is shit for drifting, as sometimes it doesnt act like a real LSD, sometimes only 1 wheel will spin :S
and as another people said: DONT RUN 15PSI, DONT RUN 12PSI WITHOUT FMIC
i has most run without a fmic maybe 9-10psi
LOL!, 3 1/2 years ago my car was STOCK, except i had a pod filter, i was running 12psi 0.8-0.9 bar for about 5-10minutes with some SPIRITED driving around. then it cost me $5000. because my turbo BLEW>>>... ($5000 for t3/t4 turbo + full turbo back exhaust & cat)
so yeah not recommended to run 15psi, or even 12psi if you car is stock.
my 2c
nah i meant its cool i wont be doin any mods for a while....
i have full comp insurance which is lucky and no i wasnt really pushing hard at all lightly greasy road....lost traction in 2nd spun into another car and hit front end into dirt embankment....was doin about 60 but no one was injured...which is most important....oh and i had just picked up the car... :) guess i learnt the hard way...
Shit - unlucky..
yeah need to take care in the wet - specially when it's lightly raining as all the grease comes up as you know..
hopefully everything will be fixed up and you'll be back on the road..
i'd suggest holding off on the mods for a while - get used to having 150kw and do some skidpan work.. than decide what to do..
hope it all goes well..
Anyone interested in an r33 half cut....i am after one and want headlights bonnets front bar radiator support and radiator....was thinkin about goin halves with someone....
Next..how hard is it to pack extra shims into the viscous lsd so it locks up better....aNd also is it dangerous to overfill the diff with oil...i have been told if you overfill it a litte by tilting car (on jack) you can fill it up more and therefore more pressure in diff so that it locks up better....however i had some concerns and they are to much pressure on diff will it blow any seals? and secondly with to much friction and heat it could warp the internals?? Can anyone confirm thisf for me???
Thanks in advance
zaffa
Thanks in advance
zaffa
About the only thing u get by over filling a diff is asking to blow the breather out or blow shaft seals that is filling it "FULL" putting more oil in the diff gets u nothing as for the clutches let a pro do them to easy to blow the diff up & its f**king hard to do
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
