http://insaniac.trdpower.com/sketchys-nissans2.htm
First of all, each to their own, and i dont mean to criticise other peoples cars, but this car has simply crossed the line.
Take the CA18DE out for sure, but dont put an RB30E back in! It doesnt even fit, check out the bonnet mods!
Excuse me while i go throw up.
Red17
https://www.sau.com.au/forums/topic/8537-one-tasteless-s13/
Aww comon its not that bad, he coulda done worse and just put a sr20de in instead but he went the whole hog instead, given it coulda had a turbo on it. But im sure it will still kik some ass and at least its an individual. Woulda been a hell of alot of work to shoehorn in that thing.
https://www.sau.com.au/forums/topic/8537-one-tasteless-s13/#findComment-124692
Originally posted by skyzerr33
heres the link
this car was at the summer nats in Canberra.
one week later it was in joondalup
with all its riceness.
http://www.pbase.com/image/10276248
gotta love the F&F sticka, the fake GTR badging and the Celica GT-4 bonnet scoop.
it look fugly
Spooted this in Rocky this arvo -- May be around for Motavation i guess
https://www.sau.com.au/forums/topic/8537-one-tasteless-s13/#findComment-126632
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
