  • 1 month later...
  • Replies 74
  • 4 months later...
hey what happens if you install a higher flowing fuel pump and a pressure regulator but dont put in bigger injectors? would the higher fuel pressure be enough?
This is very dependant on how much power you are trying to gain. For a small power increase, bumping up the fuel pressure a bit is fine. However if you increase it too much you may start having trouble getting the car to even idle properly as the increase in fuel pressure actually makes it harder for the injector valves to open, meaning that there is a delay beween when they are turned on & when the valve opens to flow fuel properly.
I did this experiment myself once on a set of VS commodore injectors & found that a small pressure increase would give a higher flow, but increasing it by much more than half a bar gained nothing. The other affect it did have however when the pressure was increased further was that they would then flow dangerously low when pulsed on & off (as they would normally in the car unless you are maxing your injectors out), meaning they'd make the car run lean.
So as I said before if you want a small power gain it's fine to increase the pressure a bit, but don't get greedy. Ultimately if you are looking for a big power gain, getting a set of high flow injectors is the go :D
thanks for that. sounds like the best idea is to try and keep the fuel pressure the same & keep an eye on fuel pressure during w.o.t if it drops then the pump cant produce enough flow and should be upgraded. sound about right?
^^ Yeah I have to agree that doesn't make any sense. If the pump fuse is disconnected you won't get any fuel. You should just turn the ignition or & off a few times for the pump to prime the fuel lines & rail. If you disconnect the fuse you get zip.
Yes this is pretty well correct, the moment you see the pressure dropping you know the pump is struggling, & if you're running higher boost or increased regulator pressure, it will have to try even harder. However if the car is leaning out & the pressure doesn't drop, check that your injectors are not going flat out. If they are it's either time to give the reg pressure a slight tweak, or if it's leaning out badly, new injectors.
Edited by Electro
  • 2 months later...
bit of a noob question, but anyway. If you install a pump that flows more fuel will you get any benfit from it if you keep the standard fuel pressure regulator? Also, I presume the car would require a tune after the fitment of a larger fuel pump??? Or the car would be running rich?
I'll start off by saying that you might need a larger fuel pump if the pressure in the fuel lines is not enough, or dropping at higher revs.
So, for the first question, if you have adequate pressure and you fit a new fuel pump, then the answer is no, you wont benefit. Most of the time, gtst fuel pump don't supply enough pressure because they're old, or whatever, so you will typically benefit.
Second question. if your original fuel pump wasn't supplying enough pressure, and you had your car tuned, then you will probably need a retune as the ECU will have been tuned to compensate for the drop in fuel.
If you have stock ecu, then the tune will be what it is supposed to be from factory, instead of too lean. However, stock tunes are generally rich anyway, for which you need some kind of aftermarket engine management.
  • 4 months later...
For those of you who are going to install the Walbro yourself:
When you take off the plastic nut, make sure you dont use a flat head screwdriver that is sharp and new you will f**kup the nut.
When you use the filter that came with the pump you'll notice it is significantly smaller than the drop down in tank floaty type one that the stock pump uses. Installing the one supplied by walbro will result in 1/4 tank issues and even 1/3 tank issues if you dont mount the bracket low enough...
Don't fret though. Walbro have seemingly placed a nice little nubby next to the suck hole to slip the stock drop down type filter right on the end of the pump and you will be able to use it on the stock assembly without modding too much (maybe a cable tie or a rubber sleeve).
When you mount the assembly back into the tank, make sure that you do so carefully and slowly and clear any tools from the fuel tank opening beforehand. If you use a torch and get a mate to help u out to point it at the mounting bracket on the side of the tank dead ahead of you, you will see it has a seperator to which the fork on the top of the mounting bracket goes over for it to slip on to. If you positioned the drop in tank filter on the Walbro correctly you will find it slides right down to the bottom and, as ive tested, it sucks right to empty.
good luck.
Im still using my stock one. no probs :)
Just did my Tomei fuel pump install on my GTS-t. I left out the supplied fuel regulator too. Also plan to upgrade to a Sard FPR or Turbosmart unit when I get my Power FC mapped with some new 550cc injectors. Pretty easy job. Did everything inline with your original post. A couple of tips I may add:
1) I applied a small amount of lubricant to the black threaded collar as it was a bit tricky to get started when I went to put it nack on.
2) I made doulbe sure no spark could be triggered by other electrical wires in the boot whilst working on an open fuel tank (fumes) by disconnecting the ground wire directly from the battery after I de-primmed the lines.
3) Make sure you don't let the screw-type hose clamps don;t fall off into the tank. I wouldn't like to try and fish them out if they did...
4) Nice and easy to see into the tank if it is less that 1/4 full
Cheers,
wooa
anyone know where i can get a tomei fuel pump from? and also how much it would be?
if someone does can you please pm me
thanx :)
edit just found one on nengun for nearly 400 delivered. Is there any other companys out there that are cheaper?
Edited by MMM
OK, Ive done mine too and took heaps of photos 'cause i thought these ones went missing and now they're back !
Oh well.... here you go anyway.
Hope it helps someone.
And i did install the little valve thingo, might aswell. Only took 2 mins :sorcerer:
Edited by Birnie
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
