Need to change whatever is in my radiator tomorrow as I'm doing a minor service on the car myself (oil filter change, oil change, spark plug change, etc). Just wondering as to which coolant is recommended to be run in a stock R33 GTST skyline these days?
Dont really want to go to supercheap and buy some cheap $5 coolant and then to find out it'll destroy the engine after 4,000k's like people have reported Mobil engine oil to come out all gluggy after 4,000k's when they serviced it.
So. Any recommendations?
https://www.sau.com.au/forums/topic/85401-coolant/
I recommend using concentrate because you can never get all the water out the block if you cant get to the drain bolt. That way the remaining water doesnt dilute the premixed coolant.
I reckon Castrol's stuff is good. Also Nissans concentrate is good. If the coolant capacity is 8L, just add 33% of it (Ie 2.7L or 3L) and fill with distilled water. Remember to drain, and rinse the system with distilled water twice (ie fill--->run for 5 mins--->drain--->fill--->run for 5 mins---->drain)
Too easy...
https://www.sau.com.au/forums/topic/85401-coolant/#findComment-1546718
having previously had an alloy radiator built for my old car i spoke to the radiator building guy about this. he has tried them all and reckons the green nulon one is the go. it's a glycol based coolant (like they mostly are). just make sure that whatever you use is suitable for use in a motor with an alloy head. not such a concern on RBs (iron block) but on my old SR20 (all alloy) you need to make sure you don't get a reaction when you switch coolant. that's the second piece of advice, pick a brand and stick to it as some brands won't go well together and can cause a chemical reation. not good.
https://www.sau.com.au/forums/topic/85401-coolant/#findComment-1546756
you don't need to use distilled water, tap water is fine.
imo, any coolant will do, don't really see the difference between more expensive brands, and as long as your car doesn't overheat, then you're fine.
(just read the label and make sure it's alright for your car)
Edited by MerlinTheHapyPig
https://www.sau.com.au/forums/topic/85401-coolant/#findComment-1546970
Yeah well if you've seen Adelaide tap water you'd start thinkin twice. Thus having a few litres of dodgy tap water still sitting in your block makes you wonder. Distilled water is cheap, no excuses.
Oh and I haven't had good experiences with Nulon's green. On 2 cars of mine the water pumps seals died soon after changing themover. Nulon green is actually a hybrid OAT/Glycol coolant.
Edited by Busky2k
https://www.sau.com.au/forums/topic/85401-coolant/#findComment-1547207
Ended up doin the coolant change over the weekend. Got a 5L bottle from Autobarn.
Autobarn plus many other skyline drivers I talked to about this on Friday night recommended that I only put 50% of the radiator's compasity of coolant in and the other 50% of the compasity of distiller water in. This, I have done and can see somewhat a bit more performance since the change.
Then again, I've also done a oil & oil filter change as well which really I think needed to be done.
Anyway! this weekend is the spark plug change. Just got to sit around the place I'm doing it at for 2hrs to let the damm engine cool down. OR! I could buy one of those huge industrial fans and let it blow on the engine for 10mins. LOL
https://www.sau.com.au/forums/topic/85401-coolant/#findComment-1550172
hey if u are talking about mixing concentrate with distilled water, generally you only need to mix around 1/3 concentrate with 1/3 water, and you would never put all the concentrate in!!
changing the coolant wont give u a performance benefit you can feel so ill assure u that the gain u felt was in your head :huh:
with the spark plug change unless your hands are very sensitive you can usually remove most of the stuff straight away when engine is hot, i usually use a rag when im touching hot parts when changing spark plugs so try that dont bother waiting u should be fine..
https://www.sau.com.au/forums/topic/85401-coolant/#findComment-1550633
changing the coolant wont give u a performance benefit you can feel so ill assure u that the gain u felt was in your head :D
Didn't say I got extra performance just from the coolant. I also did a oil service (oil change and oil filter change) to which would of helped with whatever extra performance I may of felt. Then again, cold air could of also been part of the factor for the turbo.
Or fact I probably didnt drive the car for a few hours to which had let the engine cool down. Plenty of facts could of been apart of the reason to what performance I may of felt.
https://www.sau.com.au/forums/topic/85401-coolant/#findComment-1550857
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
