After so many pages of rubbish in that other thread none of the promised tests have been done with the 2 cats in question??? What a cop out
In fairness, I think SK has been extremely busy with the racing side of things. When people try to do things in their spare time its not necessarily a "cop out" if other things get in the way.
You could always organise to do the tests or are you going to cop out? :ph34r:
My offer still stands for free analysis of the substrate for platinum, rhodium and palladium content (the metals that actually catalyse the "nasties" in the exhaust gas).
If someone can get me a gram or so to Perth, I'll have some results back in a couple of days. You can then form your own opinion as to what the unit actually is and does.
Cheers
Gav
I've put one on my 33 gtst, and then did a 4 gas analyser test on it, and it was working fine.
Test was done with car purring along as low speed, making about 10kws on dyno until results stabilised.
Test unit was a Protech FLUX 2000 (ver 7.82)
HC was 0
Co was 0
C02 was 12.4%
No 861 ppm
Nox 947 ppm
AFR 14.7:1 (as indicated by test unit and also dyno)
If the cat wasnt working the HC and Co levels would have been up alot.
Also, everyone has to remember, you dont just whack a cat on a car and it magically (no pun intended!) cleans it up perfectly. Tuning has ALOT to do with it, timing as well as fueling.
On my results, the No & Nox could have come down by playing with the timing .
Also even for just basic go/no go testing , sitting on the dyno tuning it at 10:1 levels, and your eyes arnt watering and it smells clean..........
anyone who has tuned cars on a dyno can tell you what its like, that rich, without a cat.......... especially rotaries.
Gary
You could always organise to do the tests or are you going to cop out? :)
Send me 2 cars with the different cats and an exhaust analyser and i will do it. :rolleyes:
I will have to throughly trash the cars first to calibrate them
Fastrotor, what a champion thats what we wanted to hear, someone who had actually installed one and had it tested. I'm getting mine installed this week.
I do think that BATMBL should have done some testing himself if he wanted to start all this drama instead of just starting rumours. Anyway be good to hear if others have had em tested too.
pretty sure its irrelavent anyways..... its law that the driver/ owner of the vehicle is to fit a cat that meets emissions. .. if the results are in favour of one being more legal than the other... whats the other company going to do ... pay out ppls EPA fines coz a cat that doesnt comply or reemburst them for a product they bought from them? ..... highly doubtful for either suggestions
my 2c
If you took this cat and put it on a factory setup that was all working correctly, then it will work fine.
My point was that you cant just whack any cat on a car thats running a bad tune, ie not at stoic at low power (read dead o2 sensor etc) and expect the emissions to be perfect, tuning of the motor (in the case of aftermarket) , and general condition of it all play a large part for the cat to give valid results (read legal).
Gary.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
