Intercoolers ...
Hey guys, i want a good decent jap intercooler to put onto my car. Now just wondering what my best option were, hks, trust, apexi, etc ...
Also would you recomend buying a kit. Or just the intercooler, and getting a bit of custom piping?
Just get a hybrid copy one for $175 odd, get piping done and spend the rest of the money towards other mods. The copy ones are of a decent quality otherwise you wouldnt find so many of us using it.
Cheers,
yeah, im not really interested in getting a hybrid, esp a copy, sure they mite be cheap, but heard good things and bad things about both, I would rather buy a quality product and rest assure that it will most likely have no problems whats so ever. Also heard that those hybrids can then to make a whistle sound, i couldnt stand it if mine did that. And I want to put quality parts onto my r33.
If i wanted a good cheap option, i could get a cut down truck core, and make some end tanks myself at work. But meh, I actualy want a quality product :D
Go and buy a TRUST kit, bit pricey, but have to be one of the best fitted kit available, unless you get a well made custom one , which is then even dearer. If you go custom, use a garrett core.
i got a blitz intercooler kit, was a bit expensive $1200 but im very very happy with it.
its always freezing cold :).
it uses the stock pipes as well so the input put goes under the intercooler.
kinda looks like this..
||||||__
|______
as oposed to the normal ones which look like this
___||||||||___
i do prefer the look of the normal one, but it looks cool anyways :)
edit: pictures didnt quite work.. u no what i mean tho :D
Edited by justin911
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
