firstly there are many different types of intercooler cores that are used on trucks, like stock turbo cars there are some good factory coolers and some totally crap ones.
If you get a decent core it will preform relatively well if it has well designed end tanks. However if you are aiming for high HP dont waste your time considering you will need to get it custom made up probably and this will cost a bit anyway.
I have seen a few truck cores, cut one up once actually and i wouldnt even use that on a commodore, but i have seen some that would work ok.
so it depends on the cost, what needs to be done to it and what you want it to do as to wether it is worth getting or not.
I heard people saying that to use the Freightliner cooler? It would come down to the motor the truck is using wouldn't it? Because Cummins/Detroit/Cat would all supply different intercoolers with their motors? And you can't tell me that frieghtliner stuck to one brand, coz I have seen the above 3 mentioned in these trucks.
Sumo
