Any chance I could slip in a buy for the GTR mate :)  ??
I am currently working on the R32GTR and R33GTR Road kits, bit of shock valve engineering required. Nearly finished on the shock dyno, maybe tomorrow/Sunday. I will post up a new Group Buy thread for each as soon as I am finished.
I have a lot to do;
1. R33GTST Road = done
2. R32GTST Road = done
3. Stagea S1 & S2 Road = done
4. R32GTR Road = in progress
5. R33GTR Road = in progress
6. R34GTT Road = commenced, awaiting prices
7. R33GTST Circuit = commenced
8. R32GTST Circuit = commenced
9. R32GTR Circuit = engineering in progress
10. R33GTR Circuit = engineering in progress
11. R34GTT Circuit = not yet started
12. R33GTST Drag = commenced, awaiting prices
13. R32GTST Drag = commenced, awaiting prices
14. R32GTR Drag = engineering in progress
15. R33GTR Drag = engineering in progress
16. R34GTT Drag = not yet started
17. R33GTST Drift = not yet started
18. R32GTST Driftt = commenced
:) cheers ;)
Edited by Sydneykid
  • Replies 714
Posted Images
The first kits have started to flow out, this one is going to Needajapcar;
;) cheers ;)
Edited by Sydneykid
Hey guys.
No probs buying here - I received my bilsteins within 3 days of paying - very happy.
I'll be comiong back for the rest very shortly.
Thanks for organising this one SK - youv'e done well :(
is castor adjustment kit,    replacement tension rods?  or replacement bushes with off-centre holes in them?
Replacement caster bushes, I would never ever use spherical bearings in a road suspension kit. Bottom right in the above picture.
:( cheers :D
:( cheers  :)
are you sure you can get +7deg castor or more from off-centre bushes? Do you have wheel alignment specs from your test car?
I had to wind out my castor rods a good 5cm or so to get +8deg castor on my R32, I always thought bushes could only give you +2-3 degrees or so.
As always, every car is different, I have done wheel alignments on 4 X R33GTS's recently. The best one had 5.5 degrees standard on the LHS and the worst one had 4.4 degreees standard on the RHS. So obviously getting >7 out of the one with 5.5 was easy. But getting 7 out of the one with 4.4 was impossible, a bit over 6 was the most I could get. But it sure as hell felt a lot better.
:)cheers :(
Have you got any recommendations for HICAS? It's really unpredictable that sometimes it helps but sometimes it makes my driving line bad.
Could you explain how it works and any cares should be taken when taking it off?
Are those whitelines you supply progressive springs?
Rears are progressive, so that they stay trapped. Fronts don't need to be progressive. Plus I wouldn't use progressive rate springs in the front of a Skyline, they are too front weight biased (RB's are heavy). It would make them non linear in their front end response to steering inputs.
Not really a good discussion for a Group Buy thread. This is a much discussed subject, plenty of posts on it. I suggest you do a search "Sydneykid" and "HICAS" . Thatshould answer most of your questions, if you need more info post it up in the Suspenson section. I will do my best to answer.
:D cheers :D
Edited by Sydneykid
Delivered to a Brisbane address, I'd like to order;
BNF24Z $234
BNR11XZ $234
KCA331 $119
KCA347 $132
KCA348 $281
KCA349 $114
= $1114
Would you accept a Western Union money transfer which would require picking up?
I am unable to transfer to an Aus bank acct at present.
Hi SK,
Bob & Vojtek have done some custom suspension work for me on previous cars, so I know I'm dealing with the best. Would I be able to deal with them directly for supply & fit or would going through yourself be more appropriate. Don't want to step on any toes here !
Thanks for your support.
BNF24Z $234
BNR11XZ $234
KCA331 $119
KCA347 $132
KCA348 $281
KCA349 $114
= $1114
This Group Buy is arranged through Jamex and the only way I could get the good prices was to make it very simple for them. That's why it's direct deposit only. You can drop into your local bank branch and they will be able to do a paper based transfer internationally.
:P cheers :)
Is it better to get these springs if we want to lower the car over King springs etc.....?
Cheers,
Mark.
Hi Mark if you already have Kings low springs then the rest of the kit will suite OK. I have designed the valving in the shocks with a window and the Kings low springs fit in that window. Kings super lows don't.
If you don't already have springs, then the ones in the kit are the best.
:P cheers :)
Hi SK,
Whiteline don't do fitting in house any more, they stopped a couple of months ago. PM me if you want to discuss further.
:P cheers :)
For those that need them, the Dust Cover and Bump Stop kit is now inlcuded in the Group Buy and is on the price list. The cost is $51 per pair (exc freight), so you will need 2 pair for a car set (one pair for the front shocks and one pair for the rear shocks).
:P cheers :)
Edited by Sydneykid
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
