In addition to what Grepin said before re: rear adjustable sway bar, I was also sent part number KBR20-22 (Heavy Duty Sway Bar Mount) but it says it's for a WRX?? The only part that I can figure I use from this kit is the sway mounting saddles which are almost identical to the standard ones. The rest of the kit seems not to fit anywhere?
Bleck
  • Replies 714
Posted Images
Also I have been sent KLC26 (Subaru rr Link Kit h/duty alloy). This also says it's for Impreza + WRX etc. The main components of this kit I can't seem to figure how they fit on the R33. Similar problem to previous post.
Bleck
Bleck
Bleck
Hi, seems like you have received someone elses white pastic bag. They probably have your bump stop and dust cover kit. PM sent to sort it out.
:( cheers :(
hi SK, looking at getting front/rear sway bars and rear camber kit,
just wondering if you know of any reputable company in brisbane to fit them?
cheers
The stabiliser bars are a pretty easy DIY, most of the guys do it themselves. Any decent suspension shop can fit the camber kit. Your local Fulcrum are most likely your best bet, but be aware that they will try and push their products and rubbish everyone else. So they can be a pain to deal with first up, but their work is usually OK.
:D cheers :D
Bilstein Australia have recently managed to tag onto a small production run of R33GTST and R33GTS shock absorbers that was done for the Japanese Bilstein agent. They also managed to have the valving done to our specifications as per the previous Group Buy sales.
These shocks arrived via airfreight today. So there are currently several more sets of R33 Bilsteins available for anyone interested in the Group Buy kit.
:( cheers :)
With regards to the sway bars. I believe it should be sitting on the wheels when all done up. I did mine on the jack stands would this be an issue.
Also have people done the cradle bushes on stands etc or use a proper hoist. Once again ment to be done when sitting on the wheels.
Edited by grepin
Also have people done the cradle bushes on stands etc or use a proper hoist. Once again meant to be done when sitting on the wheels.
Unlike some other cars, Skyline stabiliser bars and their links have full/free rotation, so it is not necessary to do them up with the car on its wheels.
The rear subframe doesn't carry any verticle loads, that is done by the springs. The cradle carries longitudinal and lateral loads. So once again, unlike some other cars, it is not necessary to do them up with the car on its wheels.
:) cheers :)
Hey mate, I want to do a bit of suspension work to my car but on a light budget, I've notice that my castor rod bushes on the front are a bit rooted & I can't lower my car from standard (nope not even a centimeter). The shocks are still pretty good at the moment (car's done only 45,000 kms mainly at low speed in cityscape Japan), so I'm thinking I should invest in some deacent bushes for my entire suspension (or the most important bits at least).
Would you be able to quote me with some costings for these parts?
Also I've heard that you can get bushes for castor adjustment, which is meant to be perfectly legal as opposed to adjustable castor rods, do Whiteline sell these too?
PM sent
;) cheers :mad:
i wanna get hold of the caster kit and rear camber kit, when sending the money to the supplied account, do i just put my username for the description and then send you a pm?
cheers
cheers
Hi Adam, best to send me a PM first to confirm the exact cost.
:D cheers D
1.
Does the caster kit KCA331 improve steering feel? Because I want more feel in the steering. Or am I barking up the wrong tree?
Should l get the sterring rack bushes instead (from super pro)??? Or perhaps both?
2.
Also does the subframe lock increase stress on the factory subframe bushes that get compressed?
3.
I have fairly stiff springs and shocks atm (but not as stiff as say Tein HA), would the addition of anti-sway bars front and rear make it much stiffer.....because it's acceptable at the moment....much stiffer and it would be no good. I would like more roll resistance however.
Thanks...SK you're a champ.
Sorry about the questions I just like to know exactly what I'm getting into when I buy.
Edited by simpletool
1.
2.
3.
Suggestions to your questions follow;
1. Yes, more caster improves steering feel, as well as reducing the tendancy to wander at speed and improving the turn in. Note that the caster kit bushes not only improve static caster but the further improve the dynamic caster as they resist deformation under load.
2. No, the rear subframe alignment kit actually reduces the stress on the standard bushes. They absorb a hreat dea lof the loadings that would other have ot be absorbed by the standard rubber (silicone filled) bushes.
3. Stabiliser bars reduce the roll, that's their job. They do add a little to the bump stiffness, but more than 50% less than would be the case if the roll was reduced the same amount by using stiffer springs. A stabiliser bar connects to both wheels on the same axle. Which means for a given amount of roll 50% is on the outside wheel (in the corner) and 50% on the inside wheel. For a spring to stop the roll it only works on the outside wheel. In fact the higher spring rate pushing upwards on the inside wheel actually increases the roll.
Stabiliser bars are the best bang for buck suspension upgrade you can make.
Hope that answered your questions
:( cheers :(
Hey SK
I know nothing about suspension so I apologise in advance for stupid questions :( , to lower the 33GTST safely and retain a decent ride and good handling do I need everything on the price list or are some things optional?
Hey SK
I know nothing about suspension so I apologise in advance for stupid questions :D , to lower the 33GTST safely and retain a decent ride and good handling do I need everything on the price list or are some things optional?
Sorry I missed the question.
The answer is it depends on how much you want to lower it. Following is the camber correction required for various ride heights;
This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Using lowered springs and standard shocks is covered in this thread;
http://www.skylinesaustralia.com/forums/in...howtopic=103158
Stabiliser bars are the best bang for buck suspension upgrade you can make for improved handling.
Skylines NEVER have enough caster, that's why they wander at speed, are reluctant to turn in and have poor steering feel. Hence the need for adjustable caster (radius rod) bushes.
The standard rear subframe bushes are very soft, silicone filled. They are soft when new and do wear over time until they finally leak. The rear subframe alignment kit supplements the standard bushes, stop the subframe from flopping around and at the same time give some adjustemtn of the rear squat. This allows for improvement in the rear traction.
In summary, I haven't included anything in the Group Buy that I don't think is necessary.
:nyaanyaa: cheers :laugh:
PS; the Group Buy is open until the Bilsteins run out, there is still stock at the moment.
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
