  • Replies 714
Posted Images
hey i just wanted to double check.. all 4 wheels are meant to be 350mm to the guard yeah ?? or is the rear differant to the front ?? thanks ;)
no, the front should be a bit more than the rear.... makes the car 'level'....
The Xmas rush has started, if you want suspension before the holiday break (22/12/06 to 3/1/07) then best not to delay too long.
:pirate: cheers :kiss:
There is currently zero stock of R33GTST front Bilsteins at Bilstein Australia. Production is scheduled in Germany early in the new year. I don't know how many shocks will be in the shipment, so I strongly suggest that you get in now. Jamex have agreed to take a $400 deposit to secure your shocks.
:P cheers :D
Sorry, this Group Buy is closed for shocks as there is no more stock of front R33GTST Bilsteins. I will re-open it when the next shipment is confirmed.
The other items (springs, bushes and stabilsier bars) are still available however.
:( Merry Xmas to all at SAU :)
So the bilsteins will be available again? Got a rough idea of when?
They are on the Bilstein Germany Production List, but they have no confirmed shipping date. When I know I will post it up.
:( cheers :)
damn! same here, was on my list of things to do in the new year. oh well, lets play the waiting game i guess. give me more time to save anyway. will be keeping an eye on this thread for when the arrive.
Hey Gary,
It might be in the thread somewhere, but its not in the first post...Was wondering what the model numbers for the whiteline springs are?
I know you've chosen the shocks to suit them, and added the extra groove, but are the springs just a regular whiteline product?
cheers.
hey everyone, here are some pics of the kit assembled. I know they are going under the car and all, but damn, they look good.
Oh, and I dropped my old stockers, the new kit, and the extra parts off at pedders, and they put all 4 together for me for $100 neat.
Excellent service.
Oh, and Gary, I decided to get the circlips at 342mm on the front, and 340mm at the back. This will allow 5mm sag after they set in, leaving me with 337mm Front Guard Height, and 335 Rear guard height making the car look level. This will also give 13mm rake, which is as close as I could get to your recommended 10mm setting. Hope this sounds ok!
Edited by The Mafia
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
