what is the maximum amount of neg. camber you can get with the KCA347
Depends on the ride height.
At standard ride height, 375 mm (centre of wheel to guard), they have 0.25 degrees negative standard. Plus 0.25 degrees on the standard adjuster, plus 0.75 degrees with one KCA347 kit = 1.25 degrees negative. With 2 x KCA347 kist that's 2.00 degrees negative.
At the lowest recommended ride height, 340 mm (centre of wheel to guard), they have 1.75 degrees negative. Plus 0.25 degrees on the standard adjuster, plus 0.75 degrees with one KCA347 kit = 2.75 degrees negative. With 2 x KCA347 kist that's 3.25 degrees negative.
As usual, that varies slightly from car to car.
:P cheers :whistling:
  • Replies 714
Posted Images
sk, i was just wondering about the price on the front camber adjust bushes, u have listed the rrp at $320, i was just on the whiteline site and the price on there is only $163 for the set(it says it contains two items), is there a mistake there?? dont want to pay too much if i dont have too, cheers
Whiteline lowered the price after I set up the listing, so the new Group Buy price is Whitelines current price -15%. I confirm all prices in the PM's, so you know exactly what each item costs.
Note that Whiteline's online prices exclude GST (so add 10%) plus freight.
:) Cheers :)
I am off to Bathurst tomorrow for the 12 Hour race, the race team is running (not a Skyline) and I have to do my Team Manager thing. I will be back on Tuesday, so please excuse the slow responses to posts and PM's.
:pirate: cheers :ph34r:
Hey Gary,
Your inbox is full. Trying to get the replacement part off you.
Cheers,
Shiha'b
Lot's of PM's the last 2 days, took a while to respond to them all, the inbox is now clear.
PM reply sent
:P Cheers :(
Hi Gary,
I got my Bilstein strut setup from you probably a year ago now. Performs well through the Adelaide hills, really need to get the bigger sway bars to tighten it up a bit though.
My car makes a 'crack' noise when reversing on full lock, just a single crack.
My tyre mechanic said it is the suspension, something to do with the spring rotating on the end cap, and then letting go. Do you know if this is true? Does something need to be lubricated in there?
Thanks for your help,Trav.
Gary,
need the full kit, got no money - paranoid that the shocks with the custom valves will run out and I'll be left having to go to Fulcrum for the Teins.
I know you've said you're dependant on other countries making big orders to get more stock.
How is the current availability?
May have to get the shocks then later get springs, bushes, sway bars etc as I assume the shocks are the only customised/hard to get bits?
Mike
Hi Gary,
Mine does the same thing (it's jmac's old 34) on full lock sometimes.
Hi Gary,
The spring doesn't rotate, it's not a MacPherson strut, Skylines (R32/33/34) are double wishbone front and rear. Maybe worn radius rod bushes or upper control arm bushes.
Stabiliser bars are the best value for money handling upgrade you can do, road or track.
:( Cheers :D
Hey there, I sent you a PM a few days ago about a setup for R33 GTSt.
Can you please respond?
Cheers
PM reply sent, sorry for the delay, lots of PM's over the last couple of days, took me a while to catch up.
:( cheers :D
Gary,
Mike
Plenty of stock of R33GTST Bilsteins at the moment. Will be able to accept credit card payment from 1st May.
:( cheers :D
I dont know much about suspension, but im guessing radius rod bushes and upper control arm bushes are different from:
Front Castor Kit, Camber Kit Front, Sub Frame Alignment and Stabaliser Bar sets you sell...
Are these tricky to replace? Am i best to take it somewhere and get them to supply and install new bushes?
:) cheers :)
SK, I don't actually have a PM from you. Maybe you replied to someone else or didnt hit send?
Cheers
Lee
Radius rod bushes = Front Castor Kit
Front upper control arm bushes = Front Camber Kit
Rear upper control arm bushes = Rear Camber Kit
Rear Sub Frame Alignment Kit = Pineapples
Stabiliser Bar = anti roll bar = sway bar
The recommended suspension workshops are on page one of this thread.
You need a 10 tonnes press to remove the old, worn out, standard, fixed bushes and to replace them with the new, polyurethane, adjustable buhes. Except the Rear Sub Frame Alignment Kit and the Stabiliser Bars, they are DIY with normal home garage tools.
:domokun: Cheers :yes:
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
