Thanks SK,
Springs and shocks arrived early yesterday - much quicker than I was expecting.
For anyone else contemplating getting in on this group buy before it ends - I can confirm this is quality stuff and worth every cent......
  • Replies 714
Posted Images
hey i was interested in the camber kits for the front and rear of a r33. This question is directed at sydneykid as he was the one who organised this group buy and recommended the settings.
for the 1.0 degree of adjustment of camber for what ride height (how much has the car been lowered) would this be suitable. My car is lowered 2inches so am wondering this would be enough adjustment to stop my inside of the tyre wear problem. Or would more be needed?
Thanks.
Thanks.
You really need to measure the heights, centre of wheel to guard and quote them. The "2" lower" is not much use, 2" lower than what? There are 5 standard Skyline heights, so which one is it 2" lower than?
There is only one camber kit for the front, every Skyline so far (all sorts of heights) that I have fitted a kit to has been able to achieve the desired camber settings. So I don't think you wil have a problem with the front.
The rear camber is more tricky, there is a standard adjuster on the upper control arm at the inner mount. If this is set at max positive camber and it still has too much negative then you replace that bush with an adjustable one which gives 3 times as much adjustment. This is pretty easy to do as the bush is actually located in the arm, so you can remove the arm and push the old bush out and the new bush in with a press (around 10 tonnes).
If you need more adjustment, than just replacing the inner bush gives, you need to replace the outer bush as well. This is not as easy as the bush is located in the upright, so you have to remove the upright (drive shaft, shock, rotor calliper etc) and put the whole upright in the press. This obviously involves far more labour cost or time if you DIY. A few suspension workshops around have special tools that they can use to remove the outer bush with the upright still in the car. Check your local workshops.
Armed with the height table you can easily tell whether you need 1 or 2 rear kits. I should mention that if you need 2 kits, then the car is really too low for good handling, ride comfort or power (poor drive shaft angles). So it will pay of to raise it to a more realistic height.
Hope that helps
:D chers :D
thanks sydneykid, i'll have to check the heights, the back should be fine there is still a little gap between the top of the tyre and the guard, so the car isn't super low.
Are the camber kits still for sale under this group buy?
Yep, the Group Buy is still open for all parts.
:) cheers :
hey sydney kid, are you still selling the complete suspension setup ?
:( cheers :)
sydneykid, i just meaured the hieght from the centre of the wheel and the guard and front and back was around 320mm. I assume this hieght is too low for good handling, but the handling is fine for road use (as you cant take on street corners as you would a track corner!) Would these camber kits be able to help with the inside tyre wear do you think?
Also, excuse my dumbness concerning suspension as i dont know too much about it, but for the settings that you posted when you started the group buy you have the camber setting at 1.0degrees and 0.5 degrees.
Does this mean that this kit will make a lowered car with 2.5 degrees negative camber have only 2.0degrees negative camber when using the 0.5 degrees setting?
Also you said there is only one kit for the front which is that? the kit with the 0.5 degrees setting or with the 1.0degrees setting?
Cheers.
Cheers.
The camber kits (both front and rear) are adjustable, within their range of adjustabliity you can dial up whatever you want. Because of Nissan's design of the front upper control arm, the front bushes are much larger in diameter, so there is room to get more adjustment. The rear bushes are much smaller in diameter so there is much less room for adjustment, that's why you need to use 2 kits. One to replace the standard (rubber, non adjustable) inner bush on the upper control arm and one for the outer bush on the upper control arm.
The settings I recommend are achievable using the adjusters in the Group Buy, in your case KCA348 X 1 for the front and KCA347 X 2 for the rear.
Hope that helps
:P cheers :P
Just had the Whiteline springs and Bilstein shocks fitted by Chris at Inline in Queanbeyan yesterday, he also fiddled with the adjustable swaybar settings, wheel alignment etc and wow - it's like driving a completely different car!
Can't wait to drive it again tomorrow.......
Feedback on the R33 Group Buy
My R33 GTST came from Japan with teeth shattering hard suspension. In an effort to soften the ride for Melbourne’s roads, 18 months ago I bought a set of Whiteline springs. The softer springs certainly helped the ride but the Apexi shocks fitted were way too stiff for road use (even on setting 1 of 1 to 10).
I have been looking round for quite a while for a decent set of shocks. A few weeks ago I saw the SK group buy for the R33, so I thought I would give the Bilstein shocks a go. I checked with SK and I was advised the new shocks are valved for the Whiteline springs. No need for additional springs.
I fitted the shocks yesterday and I would like to provide some feedback for other interested members.
50 KPH side streets
Old Settings - Stiff
New Settings - Choppy
Comment - Could be better
Highway cruising
Old Settings - OK
New Settings - OK
Pot Holes
Old Settings - Teeth rattling
New Settings - Fantastic
Comment - Stiff but good
Blackburn Railway Crossing
Speed Bumps
All areas so far has been an improvement. Every time I venture from home I have to cross the railway line at Blackburn. The car now glides over the crossing, not as compliant as my XR6 but quite acceptable. The same goes for speed bumps that are everywhere in Melbourne, slow down to 40 – 45 KPH and over we go.
The only area is travelling at 45KPH round the backstreets where the ride is what I would describe as choppy. Seeing the car has an empty tank of gas, I am expecting the ride will improve with a full tank of gas which will add extra weight over the rear wheels. Anyway I can live with that for the increases elsewhere.
SK, thanks for organising the group buy.
Anyone want to buy a set of Apexi shocks? – maybe good for drifting!
Cheers
Rob
Edited by Blk33
Hi Guys,
My stuff arrived today. Nice big job for after Christmas.
Would like to thank Gary very much for his time and effort put into running this group buy, and for the engineering that went into this kit also. Could you wish for a better forum member !
Merry Christmas to all, have a safe one !
Gary
  • 3 weeks later...
i'm thinking about buying into this but i'm moderately concerned by a few things....
how do we know your "engineered" rate is suitable ? is it a case of "trust" me or have you actually spent time building and testing shock absorbers before ?
what is the spring rate you are suggesting ? (i did read all 8 pages but i think i missed it somewhere....)
what was wrong with the b6 sports originally (i assume its b46-1873 & 1916 your using) did you make them softer or harder for general travel or was it simply a softening of the bump to reduce initial shock ?
obviously this is a for sale post so i'm trying to keep it sale based not technical based....
Danz
Danz
Hi Danz, I spent 3 months working on the engineering of the kits for Jamex early last year. I tested heaps of springs, shock rates, stabiliser bars, wheel alignment settings etc. I also do lots of driver training days and suspension set up clinics, so I get to drive many many cars.
I was paid by Jamex to do the engineering months ago, so I don't make anything from this Group Buy. The knowledge gained from this belongs to Jamex, not to me. The Group Buy philosophy was to give the best value road suspension kit around, with sporty handling but without a harsh ride. As you can see from the favourable comments of the guys on this Group Buy thread (and its brothers for other Skyline models) that the engineering has been pretty successful.
Whiteline indicate that their spring rates are around 25% increase from standard. The Bilstein valving was pretty good "out of the box", so it was mostly left alone. Some models required more work than others, none of them required a total revalve. The work concentrated on achieving good handling without sacrificing ride comfort, hence mostly high frequency damping. The Bilstein (NSW) shock dyno was used for this purpose, all work (including the extra circlip grooves) is done in house at Bilstein by their technicians.
The current NSW Speed Event Champion used (basically) this kit, so it is quite at home on the track. Our R34GTT fitted with this kit did an 11.9 at 120 mph (with 265 rwkw) so it is also quite at home at the drags.
Hope that answered your questions
:rofl: cheers :)
hi i was just wondering if this group buy will still be around for a while
It will stay open as long as the current stock of Bilsteins last, a small shipment of a few part numbers arrived just before Xmas and that is the last until Japan reorders (we don't have enough volume to get a production run done just for Australia). They are selling quite quickly now that everyone is back at work, so maybe a few weeks stock left. Then I will close it, I will open a new Group Buy (with new prices) once the production schedule is confirmed, that could be 3 to 6 months.
:) cheers :D
:( cheers :(
Hi Sydney kid.
I have just been having a quick look through this thread and am about to return to Adelaide from OS and want to fix up some issues with my Skyline.
I have Bilstein shocks fitted and what I believe is far too heavy springs.
I have 1.5 degree camber on the front and .5 on the rear.
I am wondering if the whiteline springs may help my issues or I might have missmatched shocks.
I still run standard sway bars. I couldnt see the specs on the spring rates etc however from the pics on here they are a lot thicker and tighter. Might be in the 400lb region.
I enjoy my track days at Mallala with the occasional drag meet. Car not used as a daily driver except runs through the hills.
Also can I find out if my shocks are suitable to be matched up with the rest of the setup. Is it as easy as maybe seeing a part number maybe. Mine actually have a threaded ajustment instead of circlips if this is any help.
I currently have all the camber and caster ajustments a strut brace.
I guess I would need springs, sway bars and the cradle kit.
One final question. If I want a set of dedicated track wheels are 17 inch instead of 18 inch wheels OK as I am thinking tyres would be more accessable cheaper.
Thanks for any help.
Edited by grepin
Guest
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
