I was wondering if anyone knows how to fix my gtr. When i start it up its fine, leave it to warm up its fun, but say 15 mins into driving it it starts to splutter and hesitate whenever coming on boost, like it is dropping a cylinder, then it'll drop a cylinder alltogether and run on 5. After that happens it wont rev above 2000rpm without all the cylinders cutting in and out making the whole car shudder, i have no idea what it could be. I have cleaned the afm's, changed spark plugs, the next on the list is cleaning the electric connections to the coils and temp sensor with some cleaner. Can anyone shed some light onto what might be happening? The motor has a blitz induction kit, exhaust and clutch, its pretty much stock.
https://www.sau.com.au/forums/topic/85472-help-needed-bnr32-gtr/
Guest Variable
Dead coil pack.
Next time it happens, pull over and while the engine is still running unplug one coil pack at a time. When you find the one where the idle does not change, you're got the culprit.
In preparation for this, you might want to remove the coil pack cover (if you haven't already)
I don't know much about these engines, but mine did a similar thing when I changed the plugs recently. Check the connection on the cdi at the back of your engine, mine was not on properly and ran like a dog. You could notice the difference when you wiggle the connection at the back.
Hope this helps!
Thanks for the sugestions guys, i will check the connections and try cleaning the plugs with an electrical cleaner incase they're dirty. I had a feeling in might be that connection, i might go to my mechanic and get him to test how stong the spark is to each coil just incase. I've also noticed that generally the exhaust note and idle not of the car has charged, its sounds lumpier and crap even when just starting up the car..
Edited by Dynamix
I'm having same issue. EVERYONE loves to say coils. Not only that, they don't seem to take any other idea as an option, but coils would normally break down when cold, rather than hot.
You really do need to check coils as well as ignitor, but my money is on ignitor.... when my ignitor finally arrives in the mail, we'll see.
To check coils, check resistance with a multi meter. Pin on Left to Pin in center, should read as little resistance as possible. Around 0.7
From the Pin on the right, to the spring which attaches to top of plug, resistance should be infinite.
i have my money on igniter.....heres what you do to check......run it until it does it...then pull over and let it idle and pull each injector plug off untill you find the dead cylinder....then change the dead cylinders coil with a good cylinders one.....repeat the test again and if it happens again on the same cylinder...its the igniter.....the ecu can also cause this but i reckon the igniter is crook
Hrm cleaned and pulled apart all the coils and ignighter, its seems to be running and idling slightly smoother then drops a cyl again after it starts to heat up a fair bit. Also pu another set of brand new spark plugs in again. I can get my hands of a set of rb25 coils for free, will they work in the rb26? I'll keep trying those idea's, thanks for the feedback guys.
Dead coil, pulled the coils off one by one and checked them when it dropped a cyl, number 5 was dead and made no difference so i swapped it with number one and then number one died and made no difference when i started it back up. Does anyone know if rb25 coils will work on the rb26, and if so will it be safe?
Easiest way to diagnose is find a friend with another R32 (rb20 uses same coils, harness and igniter as RB26 BTW) and swap out with his known good bits one at a time.
If all is swapped (including the harness - I once had a problem with the grounding lug not having a good connection) and you still have probs, check the spark plugs for cracking on the insulation.
With persistence you'll find the problem.
Edited by Gav
Thanks for that info, very helpful! I'm getting some rb20 coils this afternoon to put in to replace the one i know is dead, i also had a feeling that it may not be grounding/earthing as good as it should be aswell, so i might get an earthing kit, or make one up. The plugs are fine, no signs of cracking but the one on the dead coil is wet looking as it would be because its not sparking, other than that they are good, they're only 3 days old. If that doesn't fix the problem i can grab a whole set of coils, igniter and harness of a mate.
Coils from a S1 RB25 will work, because they use a seperate ignitor module. Coils from S2 RB25 don't work because they have inbuilt ignitors.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
