G'day
Just finished putting my FMIC on my R33 Gtst today :D and had a question as to where the best place to reconnect the vacuum hose coming out of the wastegate/standard boost solenoid. The vacuum hose I am talking about comes of the standard black intercooler piping off a factory fitting right near the boost solenoid. As my new pipes dont have this nipple/fitting I have to read boost from somewhere else.
I was just gonna T into the Vacuum line coming of the BOV, but would like to know if this is the best place or is there somewhere better.
Any Ideas? :huh:
Cheers :D
PS will put up full tutorial once I have completely finished.
https://www.sau.com.au/forums/topic/85492-just-finished-fmic-install-on-r33/
I asked this exact same question when I did my intercooler install a while ago. I was told I could either a) drill a small hole and fit a nipple coming off the piping where the stock one was, or B) tap the line into another vaccum line like off the carbon cannister or off the small line coming off the front of the intake plenum which is what I did. I haven't had any issues with connecting the line here, don't know which is the best line to join it up to though.
"Games don't affect people. If Pacman affected us as kids, we'd all be running around in darkened rooms munching on pills and listening to repetitive music."
Cheers mate I have hooked it up to my BOV vacuum hose and it seems to work fine.
  • 4 years later...
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
