G'day
Just finished putting my FMIC on my R33 Gtst today :D and had a question as to where the best place to reconnect the vacuum hose coming out of the wastegate/standard boost solenoid. The vacuum hose I am talking about comes of the standard black intercooler piping off a factory fitting right near the boost solenoid. As my new pipes dont have this nipple/fitting I have to read boost from somewhere else.
I was just gonna T into the Vacuum line coming of the BOV, but would like to know if this is the best place or is there somewhere better.
Any Ideas? :huh:
Cheers :D
PS will put up full tutorial once I have completely finished.
https://www.sau.com.au/forums/topic/85492-just-finished-fmic-install-on-r33/
I asked this exact same question when I did my intercooler install a while ago. I was told I could either a) drill a small hole and fit a nipple coming off the piping where the stock one was, or B) tap the line into another vaccum line like off the carbon cannister or off the small line coming off the front of the intake plenum which is what I did. I haven't had any issues with connecting the line here, don't know which is the best line to join it up to though.
"Games don't affect people. If Pacman affected us as kids, we'd all be running around in darkened rooms munching on pills and listening to repetitive music."
Cheers mate I have hooked it up to my BOV vacuum hose and it seems to work fine.
  • 4 years later...
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
