Cruise To Mt Macedon!!! Photo's (56k Warning)
dam i should have came on the cruise :)
i stopped at the servo  on the way out of melbourne and saw all the vic boys there
i was in the purple r32, parked next to a black s15
Ahhh i said hi on the way out to you but didn't see you all day so was wondering if you were actually on the cruise.
  • Replies 48
Posted Images
nice easy cruise, couldn't have picked a better day for it too.
well organised as always and great to have the local constabulary use their discretion on seeing us all in malmsbury. think there ended up being around 35 cars involved.
got some pics and vids i'll attempt to upload later tonight.
cheers
glad i went great to go on a cruise in good weather
i have some pics but ill have to edit them before i post
now all i need to do is get my back/neck cracked from sitting in my line for 8 hours with rock hard suspension!!!
Good work guys :huh:
Looked like a fun day for all.
BTW: Despite next non-members cruise not being until the new year... there is another Winton round coming up (Sept 10/11). All are welcome to come for a nice drive to support the Team Wang crew.
Details closer to the time.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
