hey guyz i just wanna open up this topic to get info on how to mod my r32, i'm to cars but i've always loved cars now i own my own turbo car (nissan skyline r32 gtst) so i wanna kkow eveything there is to knowo about this car and its eengine and what it can do thanx heaps guyz!
https://www.sau.com.au/forums/topic/85537-new-members-to-turbo-car-any-tips/
more boost does not equal more power. it does however mean more heat. so take that into consideration before just "more boost" theory from your mates :). if you can make the engine breath easier then its more efficient and can wind the turbo in quicker (aka reduce lag). a nice 3" split dump pipe and 3" hiflow cat and 3" exhaust will certainly help that. if it breathes more it will flow more and come on earlier.
The basic near std mods that are safe and shouldn't even require it to be thrown on a dyno..
FMIC, Exhaust, new larger fuel pump (bosch or gtr), bleeder, copper spark plugs .8mm gap (NGK BCPR6E).
Dial in 15psi, set ignition timing to 15degree's and it should run fine providing injectors are fine.
Edited by Cubes
15psi is fine on the rb20det.
RB25det I wouldn't go past 12psi.
My RB20DET turbo ran 1bar and towards the end 1.1bar for 100,000km's. (170,000km's total)
I've always believed heat is the killer of the ceramic turbine wheel, not
so much overspeeding as on the rb20det 15psi is not overspeeding.
Dial in 20psi and you may see overspeeding but to be honest, if its not tuned I'd lay bets the heat will get to it first, heat being generated by a lean detonating mixture. :D
Lean mixtures create high egt's, retarded ignition timing creates high egt's.
So.. Run it richer and dial in more ignition timing = cooler egt's. Better for the turbo.
Edited by Cubes
what do u guyz mean about psi, and where do i dial in a psi btw i have a r32 so yeah anything to do with it plz let me know cause its my first time driving a turbo and a rear with drive
also i dont have the money thats why i got a r32 :P cheap car i can spend the rest of my money on minor mods :)
so where do i get all these parts and what do each parts do for the car, any suggestions where i can get these parts cheap thanx
PSI is the boost it runs.
There's no point upping the boost unless you have an exhaust.
Running simply an exhaust with the std. intercooler I wouldn't run more than 12psi.
Replace the stock intercooler with a larger front mount item, you can then run slightly higher boost.
Before you do anything Do a bit of searching via the search button. :)
Learn what everything is and means.
Do a bit of googling also.
http://auto.howstuffworks.com/turbo.htm
http://auto.howstuffworks.com/question122.htm
http://auto.howstuffworks.com/engine.htm
http://auto.howstuffworks.com/horsepower.htm
Edited by Cubes
thanx guyz for the tips but just wanna ask another thing what do u guyz mean about when u talk about 1bar of boost, cause i thought that psi is boost then what is this bar thing can someone explain
I Don't know how much patience cubes has, but seriously man, u jus gotta start reading everything u can to find out about turbos n the rest. FAQ sections are very good. Its helpful to know how the engine works, how the turbo works, and how these components interact as a system.
howstuffworks is an awesome site, any one who doesn't think its worthwhile is ignorant.
I got an r32 gts-t coupe, it boosts 10 pounds (PSI) stock. When people say 0.8 bar or something like that, its a fraction of the 14.7 pounds mentioned before. 10 pounds in BAR would be just under 0.7 BAR (10/14.7)
The whole pound thing is that 1 BAR is what is atmospheric is. It is also what non-turbo cars drive around with. Your average non-turbo car mixes 14.7 parts of air to 1 part of fuel. Turbos force more air into the engine than the normal atmo engine, so if we boost 10PSI more thats around a 75% increase making our little 2lt much more powerful. Keep in mind, that the more boost, the more fuel is compensated by the car. Basically, the more air and fuel you can cram in your engine on 1 stroke, the better. As mentioned before, the cooler it is, the better.
You should find something like that on howstuffworks.com amongst many other useful informations.
Lastly, if you don't already have a turbo timer, get one or take it easy the last few minutes of your journey otherwise you will damage your turbs over time. Keep your car regularly serviced. If you got shit fuel economy (400km to a tank or less) change your oxygen sensor (search for a post on it). Cops love to pull skylines over: if you get pulled over, don't talk too much, and try and see if the cop is dopey with cars so you can trick him out of defecting you which leads me to this - try and keep your as obviously roadworthy as possible.
Edited by SuAvE-1
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
