after fitting my 600x300x75 fmic, and boost controller... my car is hitting approx 15psi or more..
i used to have a 450x300x75 fmic, and no boost controller.. car used to hit 10psi, and the bov made a tad quieter than normal sound..
after fitting the 600x300x75 and boost controller (no adjustment made, tried it without it too), car got up to 0.5 bar as per normal, then it rocketed up to a bar, and the blow off valve makes a very loud noise on throttle release now...
edit: this isnt flat footing it either, this is 3/4 throttle up to about 5000RPM, then changing gears.
only thing i can think of is the hose from my boost controller/bleed valve is a smaller internal size than ther old hose, as it was too short.. is the smaller hose restricting flow to the wastegate, thus pushing boost up?
any ideas would be great, cheers!
Edited by mitchy_
https://www.sau.com.au/forums/topic/85556-over-boosting/
Sorry mate, just re-read your post.
A boost controller will bring boost on much quicker than factory setup or even using a bleed. Add to that a cooler that may have a bit of pressure drop and you will have a world of difference.
Just remeber your stock boost pressure is around 9-10 psi, with a 2 stage boost control, where you get approx 2 psi less until you reach around 5000rpm.
Hoep that helps explain the difference
Edited by Steve
https://www.sau.com.au/forums/topic/85556-over-boosting/#findComment-1549102
the wastegate was plumbed after the intercooler, and before the BOV, and the throttle.
edit: i dont think i have the normal 2 stage boost anymore, ive got a microtech lt12 so it used to hit high boost all the time.
old fmic was a ARC 450x300x60, but it ran the old piping, so maybe the 180 degree bend on the return side caused a bit of pressure drop?
Edited by mitchy_
https://www.sau.com.au/forums/topic/85556-over-boosting/#findComment-1549105
I would think a bend in a pipe wouldnt be causing any type off pressure drop but more likely a restrictive intercooler core....
But previously having an ARC cooler i wouldnt think such a thing, being one off the best coolers available on the market.
Maybe it might be a faulty actuator or a split in the line to it. And you have tried running it without the new boost controller aswell?
thats all i could think off
Cheers
Adam
https://www.sau.com.au/forums/topic/85556-over-boosting/#findComment-1549122
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
