Item: 17 "Advanti racing rims and tyres
Item Condition:Rims are as new with no gutter marks or scratchers, the clear coating on the dish has just started to peel slighty but hardly noticable on the car, besides that there very good condition
Reason for Selling:Don't fit my car as these are 5 x 114.3 stud pattern
Price and Payment Conditions: NOW $650 ono PICK UP ONLY or YOU organise the Freight entirley!
Extra Info:The tyres are Goodyear 215 45 R17. the rear's are pretty much bald i guess and the front still have a few thousands kms left in them.
Contact Details:Paul on 0401738347
Priced for a quick sale, dont be afraid to make an offer.
Edited by 04rnz
wats ur best offer on these wheels? if its good then ill see if the other guy that i was enquiring about the rims replies if not ill take urs depending on ur offer including postage
If you read the first post it says YOU organise and pay the freight, if your serious give me a call and give me an offer then well talk.
CHeers Paul
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
