New Shop!!!
TKO
 Share
Im having an open day for my new shop this coming Saturday, 3rd September from 1-5pm.
Its at 926 Albany Highway, Vic Park.
Its currently getting painted and fitted out so wont be open until then.
I hope you can all cruise past and check it out as it will be my permanent spot for tinting now, no more mobile service(maybe a little).
I will be making it a SunGard Superstore(thats the brand I use) but still run my TKO business as usual.
There will be a barby and beers and im in the middle of getting NBA Jam(the old timezone machine) and Tekken so you can keep occupied while waiting for your car to get tinted.
Brett Wilkinsons "PIMPED" WRX and Adam Spiteris "CRONIC" VS ute will be on display in the showroom.
Hope to see you there.
Trent
Prices start at $245 for darkest legal film(35%) with a lifetime warranty.
Legally you cant put dark tint on your 1/4s but heaps of people get away with it.
It will also cost $50 to remove old film.
Drove past it yesterday, painters looked like they were working hard...colour scheme caught my eye.
if you ever want a graffiti mural done, let me know :rolleyes:
I have plenty of references & pics. I work up the road @ a paint store.
I of course will be hanging out there at TKO volunteering help where I can... I've got some things planned aswell... :P;)
Yeh im in market for some new tint towards summer. I called end of last summer but i thought id stick it out until it starts getting hot again :O
As soon as i need it, ill give TKO a call as ive heard all good things
Thanks boys,
I got the keys last Thursday and have been hard at work ever since.
I would like a graffiti design but probably something out the back as Im going for more of a professional look out the front.
Everyone is invited to come down and check out my new shop.
1-5pm tomorrow(3rd September) 926 Albany Highway, Vic Park.
Trent
0410 585 045
looks good... ill be in the hunt for some tint very soon, might have to come by and see what u got to offer... i saw a bit of ur work at Autosalon & it looked promising.... nice site btw, i like it... :D
 Share
    • Thanks to @V35_Paul there is an oem stereo available on gumtree, but the fascia is slightly different. It has a flip up screen as opposed to my pop up screen. Am I able to disconnect the radio/cd player from the fascia to use it on mine?
    • Had to google what a quart is lol.. so rough as guts a litre. That's a bit excessive, also what oil weight are you running? The whole steam cleaning idea isn't too far fetched either. Maybe as you suggested, turn off the WMI (assuming your Kebabtech pulls timing, boost, etc.) and run it for a bit and see if there are any noticeable changes in spark plug colouring.
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
