Few people have been asking what I'm doin with my cars these days. For those that asked/interested, here's some of the shit that I've started that I'll probably never finish...
Project 1:
AE86 for race use. So far:
$650 AE86
$350 TRD 2 Way LSD
$1600 CA18DET, gearbox, ECU, loom, turbo etc
$800 8-point Rollcage
$100 Sabelt racing harness
$27 Fire Extinguisher
Project 2:
Street driven widebody R32...
BN Sports R32 Widebodykit (50mm either side)
SSR 18"x9.5" in front and SSR 18"x10.5" at the back
RB25DET (Still being built/pieced together)
Trust TD06-25G (Will most probably be sold as it is totally non street use friendly... starts spooling at 5000rpm and then wooshka)
HKS external wastegate
custom lowmount manifold
no more details due to it being a combination of being a top secret and "make/get as we go" project.
Some teaser pics (with stock sized rims for reference):
I'll update this thread... whenever something happens... which won't be soon.
I think I should just sell it all and get a Vol... i mean a Stagea.
https://www.sau.com.au/forums/topic/85585-projects/
lol monkey the hachi wont take 5 years... the skyline on the other hand if u still have it... :D
sell the bitch and bring in that thing u were saying from last time.
oh and btw got ur messages today lol... left the phone at my cousins house on friday night.
https://www.sau.com.au/forums/topic/85585-projects/#findComment-1550794
I just saw in the for sale section a 1989 version of my car's (mine 1993) selling for 10 grand... so I'm tempted to sell mine too. With the new P-Plate rules, it seems my car's actually eligible :D
I want to finish the hachi in a couple of months. Driftline being the efficient guys they are should have the engine in before the end of next month (maybe even next week). After that its all just cosmetic shit and bolt on stuff.
I might just slap a Vertex kit on the R32, respray it and sell it.
https://www.sau.com.au/forums/topic/85585-projects/#findComment-1551535
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
