predator Posted October 24, 2005 Share Posted October 24, 2005 any update on the Whiteline springs on this one? been many weeks now? Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1663467 Share on other sites More sharing options...
Chris32 Posted October 24, 2005 Share Posted October 24, 2005 Waiting also I PM'd Sydneykid on friday and was told still waiting for springs Im in a bit of a shit situation as I sold my coilovers and have borrowed some suspension to put in the car for the time being, but I need to get this back, hopefully by the weekend Hoping they will be here this week, as i'm off for a bit of a break from work soon and want to get the car sorted before I go Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1663480 Share on other sites More sharing options...
Sydneykid Posted October 24, 2005 Author Share Posted October 24, 2005 (edited) any update on the Whiteline springs on this one? been many weeks now? PM sent with updated production schedule. cheers Edited October 24, 2005 by Sydneykid Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1663950 Share on other sites More sharing options...
Chris32 Posted November 7, 2005 Share Posted November 7, 2005 Got mine this morning! Great stuff Only got a few questions - I have had a look but haven't been able to find what the ride heights will be at the various grooves? I have seen it somewhere before but I cant find it now Also, will the corresponding groove on the front give the same ride height as the rear? Bump stops and dust covers arrived also, looks simple enough to set them up as you have posted. I will be putting them together myself, and hints or tips for me? The rear springs also didn't correspond exactly to the product number on the group buy sheet, but the last 3 numbers did so I assume these are the correct springs? The ones I got are product number C90-20191 Thanks for all your help, Chris Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1694726 Share on other sites More sharing options...
Sydneykid Posted November 7, 2005 Author Share Posted November 7, 2005 Got mine this morning! Great stuffOnly got a few questions - I have had a look but haven't been able to find what the ride heights will be at the various grooves? I have seen it somewhere before but I cant find it now Also, will the corresponding groove on the front give the same ride height as the rear? Bump stops and dust covers arrived also, looks simple enough to set them up as you have posted. I will be putting them together myself, and hints or tips for me? The rear springs also didn't correspond exactly to the product number on the group buy sheet, but the last 3 numbers did so I assume these are the correct springs? The ones I got are product number C90-20191 Thanks for all your help, Chris <{POST_SNAPBACK}> Hi Chris, wow that was quick delivery, they only left around 3.30pm Friday. Yep C90-20191 = 70191 (Should have had 70191 on the box) The shocks come with the circlips in the standard groove. Since the springs are 30 mm lower (than standard springs) that means the standard groove will give you 30 mm lower than standard (when new) height. Remember that springs take a couple of days to settle to their height and usually come down around 5 mm from when they are first installed. All measurements following are centre of wheel to guard vertically; Standard (new) height is ~385 mm front & ~375 mm rear 355/345 mm are the standard circlip positions 347/338 mm are one circlip groove down 339/ 330 mm are two circlip grooves down 331/328 mm is the lowest of the 6 circlip gooves Note that 355/345 mm is the best handling positon. You will need a spring compressor to remove the standard springs, as they have a lot of preload. Hope that was of some help cheers 1 Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1695158 Share on other sites More sharing options...
Chris32 Posted November 7, 2005 Share Posted November 7, 2005 Hi Chris, wow that was quick delivery, they only left around 3.30pm Friday.Yep C90-20191 = 70191 (Should have had 70191 on the box) The shocks come with the circlips in the standard groove. Since the springs are 30 mm lower (than standard springs) that means the standard groove will give you 30 mm lower than standard (when new) height. Remember that springs take a couple of days to settle to their height and usually come down around 5 mm from when they are first installed. All measurements following are centre of wheel to guard vertically; Standard (new) height is ~385 mm front & ~375 mm rear 355/345 mm are the standard circlip positions 347/338 mm are one circlip groove down 339/ 330 mm are two circlip grooves down 331/328 mm is the lowest of the 6 circlip gooves Note that 355/345 mm is the best handling positon. You will need a spring compressor to remove the standard springs, as they have a lot of preload. Hope that was of some help cheers <{POST_SNAPBACK}> Cool, thanks for that. I will set them up at the reccomended height. Will be a big differance from the 308/305mm ride height previous! Shipping came quite quickly, and all arrived ingood condition Another quick question, I know this sounds stupid, but the centre nut that screws onto the shaft, once the tops are on do you do this all the way up or just enough to hold it all on there? I have seen some shocks where it sits right up the top, and others that sit right down as far as it can go. Is it worth securing the dust covers with a zip tie around the body of the damper? I take it the bump stop sits in the groove of the dust cover like in your picture, but I can see the dust cover being able to slide up the damper body unless its secured While I'm on that topic as well, should I pull the dust cover/bump stop hard against the damper body, or let common sense tell me I might be best to allow them to have a bit of give in them so they can move around a bit with the suspension Thanks, Chris Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1695207 Share on other sites More sharing options...
Sydneykid Posted November 8, 2005 Author Share Posted November 8, 2005 Cool, thanks for that. I will set them up at the reccomended height. Will be a big differance from the 308/305mm ride height previous!Shipping came quite quickly, and all arrived ingood condition Another quick question, I know this sounds stupid, but the centre nut that screws onto the shaft, once the tops are on do you do this all the way up or just enough to hold it all on there? I have seen some shocks where it sits right up the top, and others that sit right down as far as it can go. Is it worth securing the dust covers with a zip tie around the body of the damper? I take it the bump stop sits in the groove of the dust cover like in your picture, but I can see the dust cover being able to slide up the damper body unless its secured While I'm on that topic as well, should I pull the dust cover/bump stop hard against the damper body, or let common sense tell me I might be best to allow them to have a bit of give in them so they can move around a bit with the suspension Thanks, Chris <{POST_SNAPBACK}> Hi Chris, you should notice a big improvement in handling and traction compared to 308/305. There would have been all sorts of strange suspension geometry at the height. Tighten the shock nuts until the thread stops, don't use excessive force. The top of the dust covers is held in place by the bump stop, so the bottom has to be free to move up and down. Cheers Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1697317 Share on other sites More sharing options...
grandmasterb Posted November 8, 2005 Share Posted November 8, 2005 SK PM sent regarding GB and suspension set up. Cheers B Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1699068 Share on other sites More sharing options...
Sydneykid Posted November 8, 2005 Author Share Posted November 8, 2005 SK PM sent regarding GB and suspension set up.Cheers B <{POST_SNAPBACK}> PM responded to, there are currently 2 sets of Bilsteins in stock for this model. So don't wait too long or they will be gone. cheers Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1699851 Share on other sites More sharing options...
Oosh Posted November 9, 2005 Share Posted November 9, 2005 Okay, my shocks, springs, and bump stops/dust covers have arrived, the sway bars are still in transit, but i'm a little confuse re: circlip grooves. As you can see (despite the watermark's besst efforts): I seem to have 7 grooves (3 silver, 2 yellow, then 2 silver) rather than 6, so which is which height SK? Cheers, - Ash. Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1700546 Share on other sites More sharing options...
Chris32 Posted November 9, 2005 Share Posted November 9, 2005 Yeah, mines the same as that, there are 2 grooves that look like they where there to start with I will go with the lower of the 2 when I set mine up I reckon Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1700580 Share on other sites More sharing options...
Chris32 Posted November 9, 2005 Share Posted November 9, 2005 Put a front and a rear together last night One question, are the springs supposed to remain captive at full extension? I thought I'd need spring compressors but didn't need to use them at all. the rear spring is pretty much captive, you can move it around ever so slightly, but the front has a good few mm of movement? Is this because the springs are a bit lower than stock? Circlip height is as reccomended Chris Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1702365 Share on other sites More sharing options...
Oosh Posted November 10, 2005 Share Posted November 10, 2005 Did you need compressors to take the stock ones apart (to get the top cap bit)? Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1702506 Share on other sites More sharing options...
Chris32 Posted November 10, 2005 Share Posted November 10, 2005 I got a mate who owns a wrecking yard to get me a set of tops and rubber bits etc, so not sure mate. I am guessing you would, as the stock springs are higher?? Downside I have a brand new spring compressor set I don't need! Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1702570 Share on other sites More sharing options...
Sydneykid Posted November 10, 2005 Author Share Posted November 10, 2005 Hi Guys some questions, which I will do my best to answer; * The circlip is in the standard groove when the shocks are shipped from Bilstein. * The Whiteline springs should be lightly trapped. * You will need spring compressors on the standard springs as they have a lot of preload, about 300 lbs per inch. So don't just undo the shock nut, stuff will hit you at very high velocity. Hope that helps Cheers Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1702660 Share on other sites More sharing options...
Chris32 Posted November 10, 2005 Share Posted November 10, 2005 Cool, I will see how they go, I am putting them in on the weekend Chris Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1702873 Share on other sites More sharing options...
Oosh Posted November 10, 2005 Share Posted November 10, 2005 (edited) Hi Guys some questions, which I will do my best to answer;* The circlip is in the standard groove when the shocks are shipped from Bilstein. * The Whiteline springs should be lightly trapped. * You will need spring compressors on the standard springs as they have a lot of preload, about 300 lbs per inch. So don't just undo the shock nut, stuff will hit you at very high velocity. Hope that helps Cheers <{POST_SNAPBACK}> Okay, so which groove is for your recommended 330mm again? Edit: Oops that should be 350mm Now my bars have turned up, yay, but i seem to have received a BNF28Z rather than a BNF26Z. What are my options here? i.e. The car is almost 100% street driven, I was intending to run both bars at their softest settings, where does BNF28Z at its softest sit in relation to a BNF26Z? Cheers. Edit: I suppose i should double check that BNF26Z IS the correct one for this "kit", as you actually have BNR26Z down for both, being obviously a typo i assumed the F. Edited November 10, 2005 by Oosh Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1703545 Share on other sites More sharing options...
Sydneykid Posted November 10, 2005 Author Share Posted November 10, 2005 (edited) Okay, so which groove is for your recommended 330mm again?Now my bars have turned up, yay, but i seem to have received a BNF28Z rather than a BNF26Z. What are my options here? i.e. The car is almost 100% street driven, I was intending to run both bars at their softest settings, where does BNF28Z at its softest sit in relation to a BNF26Z? Cheers. Edit: I suppose i should double check that BNF26Z IS the correct one for this "kit", as you actually have BNR26Z down for both, being obviously a typo i assumed the F. <{POST_SNAPBACK}> To stop people simplistically copying the kits, I have slipped in the odd twist. You have the right stabiliser bars, as was confirmed via PM at the time of ordering I recommend 355 mm front and 345 mm rear, which are the standard grooves (the Bilstein are shipped with the circlips in the standard grooves). I don't recommend 331 mm front 321 mm rear, as it is too low for good ride and handling. If you want it that low for looks then that is 3 circlip grooves lower than standard. Each circlip groove is 8mm from the next groove. Hope that helps Cheers Edited November 10, 2005 by Sydneykid Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1704518 Share on other sites More sharing options...
Oosh Posted November 10, 2005 Share Posted November 10, 2005 Well i just messed that right up didn't i? I have a few more Q's on this but I'll take them to PM. Thanks for the info. re: ride height. Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1705334 Share on other sites More sharing options...
Chris32 Posted November 14, 2005 Share Posted November 14, 2005 Mines all in, took a bitof playing around to get the heights right but it wasn't too hard Initially my circlips where on the lower of the two grooves that where machined stock This proved to be too low, so out they came and where put on the higher of the two stock grooves This gave me a ride height of around 340mm, so pretty happy with that, apart from the front right which is 334mm so I might bump that one up to the next groove to get them all even. Just ran out of time otherwise i would have done that I will also see what height it settles at before I get all the allignment done, as I might need to bump it up a bit still, depending on where it settles On the road ti feels really good Link to comment https://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/page/4/#findComment-1711673 Share on other sites More sharing options...
