R32 Gtst Whiteline & Bilstein Suspension
Sydneykid
Just checked my front tires for the first time in a while and the insides of each are down to the metal strips :\!. Looking at them its asif the tires dont sit straight down instead they angle out. Whats worn? I presume a full kit will fix this?
Sounds like excessive negative camber. Generally ride height is the first place to look for excessive tyre wear. What is the ride height , front and rear all 4 corners, centre of wheel to guard?
It may just need a camber kit, front $272 and rear $123.
:P cheers :(
Hello all
Just a few questions about my r32gtst 4 door.
Currently drivers side front tyre is wearing on the inside edge. It has noticably more camber than the passenger side which is wearing out as well but not as bad.
Front Tyres need replacing now because of the wear on the inside edge rest of the tyre is still fine
Heights Centre wheel to gaurd
Front Drivers side 342mm passenger 360 - measuring the springs Drivers Side is shorter than the other by 10mm missing one of the bottom coils - is this normal
was 350 and 360 when bought 1 year ago
the springs and shocks that are in the car are supposed to be stock same stuff used to clear compliance in adelaide(Possibly a mix and match of second hand parts)
the front upper mounts are after market solid items with no camber adjustment and no rubber mounts to cause issues can post photos if you want
rear tyre wear is fine - height drivers side 360 passenger 370mm
What would be the best way to fix the camber to start with then put the ride heights to 350 or 360 even left to right?
Would it possible to fix camber first then do whatever else is needed later?
Can you tell me what legal ride heights would be for my car in SA? - Clearing a defect is a pain
Are the fully adjustable camber upper arms street legal?
Edited by shaunr34gtt
Hello all
1. Heights Centre wheel to gaurd
2. the springs and shocks that are in the car are supposed to be stock same stuff used to clear compliance in adelaide(Possibly a mix and match of second hand parts)
3. the front upper mounts are after market solid items with no camber adjustment and no rubber mounts to cause issues can post photos if you want
4. rear tyre wear is fine - height drivers side 360 passenger 370mm
5. What would be the best way to fix the camber to start with then put the ride heights to 350 or 360 even left to right?
6. Would it possible to fix camber first then do whatever else is needed later?
7. Can you tell me what legal ride heights would be for my car in SA? - Clearing a defect is a pain
8. Are the fully adjustable camber upper arms street legal?
Hi, I have taken the liberty of numbering your question, save retyping;
1. Standard (new) height is 380 mm front and 370 mm rear, they usually come down 5-10 mm as they get older. Lower on the driver’s side is not unusual, especially if the car spends a lot of its life with just the driver in it.
2. Maybe, or could be juts sagging from age and worn out shocks. With no damping the springs wear out fairly fast.
3. Check the spherical bearings, they usually wear pretty fast. R32/33/34’s have double wishbone suspension, you can’t adjust the camber at the shock/spring unit. You need to do it on the upper arm.
4. That’s is around standard height as per #1, sagging front is not unusual, that were all the weight is
5. My guess is the springs are worn, and most likely the shocks. You really need to replace both. Get the heights right and then adjust the camber.
6. Nope, the sagged springs are casing the camber problem
7. Refer #1, but most guys don’t seem to have problems at 360/350, it’s only when you get down to 340/330 that the height becomes an issue. Remember it’s 100 mm under the lowest point of the car, usually the exhaust where it goes under the rear subframe. The bigger the exhaust, the more likely it will be too low.
8. Nope, replacing bushes in the upper arms with adjustable ones is legal. Hence why the Whiteline camber kits are popular.
For camber kits, this is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Hope that was of some help
Cheers
Gary
I figured it would be the springs was hoping not looks like im going to start saving now
Hi Gary - a great help.
Sorry with question 3 I misworded it
The front upper arms are after market solid items with no camber adjustment and no rubber mounts to cause issues shown in the pic. The top mounts of the shocks are standard.
as long as the upper arms arent a bit shorter than stock i shouldnt need the adjustable bushes for the front as only looking to go 360 - 350mm for best handling - has a gtr front bar on it at the moment looks low enough. Any lower and it wont get up my driveway
With Q7 is 100mm australia wide(im in SA)?
Are the springs the same no matter what height you have the circlip at?
Where can i find the sperical bearings?
1. With Q7 is 100mm australia wide(im in SA)?
2. Are the springs the same no matter what height you have the circlip at?
3. Where can i find the sperical bearings?
Suggestions follow;
1. It's an ADR (Australian Design Rule)
2. Yes
3. Inside the upper arms (where the bolts go though), they allow the same 3 dimensional movement as rubber does in the standard arms.
:) cheers :P
  • 3 weeks later...
do you have any idea when whiteling will be making another batch of 32 springs
My understanding is that a production run has been completed on Skyline springs, but they are not yet at the Whiteline warehouse. They are expected this week.
:) Cheers :)
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
