i just got a front pair of these shocks revalved for stiffer springs etc, and they are AMAZING.
ive had japanese coilovers (tanabe) before, ive borrowed my mates cheap and nasty HSDs and now ive got bilsteins, they are so much better than anything else ive had.
both more comfortable and handle heaps better
cant wait to take em out to the track!
Edited by salad
if this group buy is still on can i check the availability of the front Hduty swaybar - BNF28 and the rear XHduty swaybar - BNR26X
is there a kit which includes the bushes and links aswell?
PM sent
:no: cheers :D
Hi sydneykid
im interested in these and can i have sum prices inc shipping to melbourne PM me..
-Front & Rear Springs (im looking to lower my car only 25mm front and rear coz i have 19inch" rims and any lower it will rub. so would u supply lower 25mm springs?)
-Front Bilstein & Rear Bilstein Shocks
cheers
bill
SK i have lowered my car quiet abit...
Center of rim to gaurd on both front and rear is 295mm, and im not exaggerating at all lol
I am goin to grab a few bits off you to go with some whiteline stuff i have (mainly after some traction so adjustin the camber as much as i can), is bein that low going to damage anythin (apart from my kit and exhaust.. hahaha)??? I noticed better handlin when it was 10-15mm higher but i prefer the low look.
Shoot, where to start............just a short list of stuf that your are risking;
1. Drive shaft breakage is possible
2. CV joints will wear very fast (they are also soaking up extra power due to the extreme angles)
3. Steering tie rods (front and rear) are under extreme loads
4. Every single bush in the front and rear suspension will wear out excessively fast
5. The strut towers will eventually crack (both front and rear) due to the lack of bump absortion
6. The rear cradle will crack around the upper and lower control arm joints also due to the lack of bump absorbtion
7. You will suffer poor traction, so it won't stop or accelerate anywhere near its potential
8. The front and rear windscreens are stressed members, so they will eventually crack as well
9. Every electronic component is being subject to higher than its design levels of NVH, so they will eventually start to fail one by one
10. Your chiropractor will make a small fortune fixing your lower back problems
That's pretty much the major items, there are quite a few minor ones of course, but I think you get the drift.
:D cheers :(
Edited by Sydneykid
Alright Gary... whats the lowest i can be without stressing the suspension etc too much?? :O Dont tell me 330mm coz thats heaps hahaha
I use camber correction as the first measuring stick as to how much a car can be lowered. When the camber gets grossly excessive, then you know you have lowered it too far. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Using that rule of thumb, 340 mm front and 330 mm rear is a low as I would go, keeping in mind that they handle best at around 350/340. So even at 340/330 you are sacrificing handling for looks.
:thumbsup: cheers :no:
Edited by Sydneykid
SK,
will the shocks work on standard gtst springs? and just to confirm that they are height adjustable? what's the advantage of going to the whiteline springs also?
i want something that i can adjust about 20mm lower, but put back to standard if i need to
but i also want the ride to be comfortable as this car probably won't ever see track work
and finally, just confirming that the price is for a pair? so a set of 4 shocks will be around $1140?
thanks,
Warren
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
