Hi Gary,
Can you please advise the final cost of the complete kit sent to Brisbane please.
I am chasing the entire kit, need to replace my super-stiff and annoying Tein coilers front and rear the rest of the suspension is standard.
Will i need the bump stops?
Kind regards
Simon
Edited by Simonster
Hi Gary,
Kind regards
Simon
PM sent
:D cheers :D
shocks went in today and work great!!
car rides nicely and very smooth still - onyl slightly harder than stock, but definately handles better and sits 24mm lower than stock
for everyone's reference, i used the bilstean shocks on stock springs dropped down 3 circlip grooves...
i might get the rear guards rolled for precaution given that i'm running 9" rears with +40 offset
a question for everyone though:
when i picked the car up, they said that something else was also worn out. they pointed it out on the car, but i don't know what its called. it connects from the lower control arm to something under the engine. looks like a rod with a ball-shaped thing on the end
can anyone enlighten me as to what it is and whether or not it actually might need replacing?
oh, and i had the suspension fitted at Vitanza Tyres in Fortitude Valley, Brisbane. Highly recommended for tyres and suspension
cheers,
Warren
possible radius rod bushing but im really not too sure what ur describing by ur description. Take a pic if u can.
yeh thats what i reckon it is too, also know as caster rods and tension rods.
yeha from what ive been told they prevent movement of the control arm under accel and braking in order to prevent castor and camber changes in the steering geometry...But as i sed im unsure whether this is the part he means...need a pic to be 100% sure
ok so this is a picture of what is supposedly worn on my car..
it has some oil/moisture around it, but not as bad as in this picture
so my questions are:
- what is it called?
- are they on front and rear or just front?
- where can i get a replacement?
would appreciate any help!
Warren
ok i have done some more research..
i think they are castor rod bushes...
and i understand that new ones can be had through the group buy, is that correct SK?
do those have the same functionality as the stock ones?
cheers,
Warren
Theyre caster rod/radius rod bushes.
i just had mine replaced coz they were completely cracked
the group buy has them, KCA331.
otherwise theyre about $360 from nissan i think
the stock ones arent adjustable whereas the whiteline are.
I'd say thats the only difference....probably last longer too
Anyone considering an R32GTST kit should move quickly as there is only 1 set of R32GTST rear shocks left in stock. No production is currently scheduled, so it may be many months before Bilstein do another production run.
There is no alternative shock available, R33 and R34 rear shocks are too long and R32GTR rear shocks have the fork at the bottom not the bush.
:wub: cheers :yes:
There is only 1 (yes ONE) set of R32GTST rear Bilsteins left in stock at Bilstein. There are no shipments planned and there is no production schedule. So when this set is sold I will close the Group Buy.
:D cheers :wave:
hi sk
will you be able to ship a set of front and rear shocks to Cape Town; South Africa? what will shipping cost be?
Thanks
Shipping will be more than the shocks cost, try the SA Bilstein agent.
:P cheers :D
Guest
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
