plz clear your PM box SK :O..  Have transfered the money for my order today.. Just need to send the details that its actually for.
Sorry, I logged off early last night and 20 PM's arrived and filled the inbox. It's OK now.
Will the shocks work just as well with my kings springs lows?
Are the rates and lengths compatable?
Yep, the Kings "lows" are similar in rate and height to the Whiteline springs used in the kit. I don't know about Kings "superlows" though, haven't tested them.
:) cheers :)
Okay lets do this thing, put me down for: shocks, springs, adj. swaybars, bump stops & dust covers.
Cheers,
- Ash.
Thanks for supporting the Group Buy, please PM me with the details.
:) cheers :)
Sydneykid,
I noticed all your prices seem to be for the separate item and not the packages. Can you get a discounted rate on a Whiteline Works package?
Sydneykid,
If you add up the items you will find the Group Buy is much cheaper than the Whiteline Works Package with the same items included. Plus I have chosen specific sizes of bars, shock valving and alignment settings that work together to give a total result.
:) cheers :)
A couple of guys have asked me about the front camber kit KCA336, and its cost. As you can see it is a very complex kit with a lot of components;
In the kit there are;
8 X polyurethane bushes
2 X steel offset drilled shafts
4 X aluminim collars
2 X high tensile bolts
4 X high tensile nuts
4 X centre drilled steel shafts
4 X high tensile spring washers
1 X set of instructions
1 X "Whiteline Test Pilot" sticker
This enables you to adjust the camber at the outer upper control arm. It also replaces the rubber bushes (with polyurethane bushes) on the inner upper control arm. Both of these are high wear points on R32's, almost every R32 I see has worn upper control arm bushes. This is mostly due to their age, but Nissan obviously saw room for improvement in the design of the upper control arm. The R33 version of the front upper control arm spreads the load over a wider area in an attempt to reduce the wear on the bushes.
So you do get a lot for your money and most R32's need it badly.
:D cheers :blink:
Edited by Sydneykid
Hey Sydneykid,
Im keen to go ahead with the purchase now,
I am after front and rear springs,shocks, bump stops and dust covers
I worked it out to be $1297 in total
is this correct? I need to pay via my credit card, how do I go about this?
Regards, Chris
Hey Sydneykid,
Regards, Chris
Sorry Chris, Jamex don't take credit cards. In order to get the Group Buy pricing I had to agree to their payment terms.
Following are the prices for your requested kit;
R32GTST
73175 Front Springs $144.00
70191 Rear Springs $144.00
Front Bilstein Shocks $561.00
Rear Bilstein Shocks $561.00
W0921 Bump Stop & Dust Cover $102.00
Zero Freight $-
Sub Total $1,512.00
Less extra 5% $75.60
Total $1,436.40
PM me for further details
:) Cheers :)
is this group buy still running
Yes, there are still a few sets of R32GTST Bilsteins in stock.
:) cheers :D
Edited by Sydneykid
Hi,
Im the one who was asking you about the tein's for sale etc before... and you recommended this group buy.
I was wondering.... These are Blistein Adjustables right? How much would it cost for a front and rear set of bilsteins, springs, dust covers, and bump stops. And do you think i could get anywhere near this selling my tein coilovers depending on whether they are HA's or HR's offcourse. Do you think this is a wise move? I kno everyone raves about how good coilovers are, but i just dont see the practicality of having tein coilovers, they are just too damn hard, you get less grip in my opionion no matter where u go...it just breaks traction to easy and i have a set of 255's and 235's on the 32. Its only running like 12psi through a side mount, and with new tyres still manages to spin up quite a bit in first let alone go around corners with not that much power ....this suspension setup should ssee some more "positive" traction shouldnt it? should the amount of roll be almost matchable?
Your help would be appreciated...
Cheers, David.
Hi,
Cheers, David.
Hi,
Cheers, David.
Hi David, I really have no idea how much you can sell the Teins for, some guys like the hard ride and will pay $good for it. Try advertising them in the For Sale forum or on Ebay, I guarantee that you will sell them, I just don't know for how much.
Stabilser bars should control roll, not springs. That's why the Teins are so hard, they try to do everything with the spring rate. I can assure you that you won't get a better handling/ride than the Group Buy for anywhere near the cost of the kit.
The Group Buy price for 4 springs, 4 shocks and 2 pairs of bump stops and dust covers is $1487.80 with free freight and the extra 5% discount for orders over $1K. The prices of the full kit are in the first post on this thread.
Hope that was of some help
:P cheers :D
Guest
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
