Waiting also
I PM'd Sydneykid on friday and was told still waiting for springs
Im in a bit of a shit situation as I sold my coilovers and have borrowed some suspension to put in the car for the time being, but I need to get this back, hopefully by the weekend
Hoping they will be here this week, as i'm off for a bit of a break from work soon and want to get the car sorted before I go
any update on the Whiteline springs on this one?
been many weeks now?
PM sent with updated production schedule.
:D cheers :D
Edited by Sydneykid
Got mine this morning! Great stuff
Only got a few questions -
I have had a look but haven't been able to find what the ride heights will be at the various grooves? I have seen it somewhere before but I cant find it now
Also, will the corresponding groove on the front give the same ride height as the rear?
Bump stops and dust covers arrived also, looks simple enough to set them up as you have posted.
I will be putting them together myself, and hints or tips for me?
The rear springs also didn't correspond exactly to the product number on the group buy sheet, but the last 3 numbers did so I assume these are the correct springs? The ones I got are product number C90-20191
Thanks for all your help,
Chris
Chris
Hi Chris, wow that was quick delivery, they only left around 3.30pm Friday.
Yep C90-20191 = 70191
(Should have had 70191 on the box)
The shocks come with the circlips in the standard groove. Since the springs are 30 mm lower (than standard springs) that means the standard groove will give you 30 mm lower than standard (when new) height. Remember that springs take a couple of days to settle to their height and usually come down around 5 mm from when they are first installed.
All measurements following are centre of wheel to guard vertically;
Standard (new) height is ~385 mm front & ~375 mm rear
355/345 mm are the standard circlip positions
347/338 mm are one circlip groove down
339/ 330 mm are two circlip grooves down
331/328 mm is the lowest of the 6 circlip gooves
Note that 355/345 mm is the best handling positon.
You will need a spring compressor to remove the standard springs, as they have a lot of preload.
Hope that was of some help
:blink: cheers :blink:
  • Like 1
Cool, thanks for that. I will set them up at the reccomended height. Will be a big differance from the 308/305mm ride height previous!
Shipping came quite quickly, and all arrived ingood condition
Another quick question, I know this sounds stupid, but the centre nut that screws onto the shaft, once the tops are on do you do this all the way up or just enough to hold it all on there? I have seen some shocks where it sits right up the top, and others that sit right down as far as it can go.
Is it worth securing the dust covers with a zip tie around the body of the damper? I take it the bump stop sits in the groove of the dust cover like in your picture, but I can see the dust cover being able to slide up the damper body unless its secured
While I'm on that topic as well, should I pull the dust cover/bump stop hard against the damper body, or let common sense tell me I might be best to allow them to have a bit of give in them so they can move around a bit with the suspension
Thanks, Chris
Thanks, Chris
Hi Chris, you should notice a big improvement in handling and traction compared to 308/305. There would have been all sorts of strange suspension geometry at the height. Tighten the shock nuts until the thread stops, don't use excessive force. The top of the dust covers is held in place by the bump stop, so the bottom has to be free to move up and down.
:D Cheers :D
SK PM sent regarding GB and suspension set up.
Cheers B
PM responded to, there are currently 2 sets of Bilsteins in stock for this model. So don't wait too long or they will be gone.
:) cheers :)
Okay, my shocks, springs, and bump stops/dust covers have arrived, the sway bars are still in transit, but i'm a little confuse re: circlip grooves.
As you can see (despite the watermark's besst efforts):
I seem to have 7 grooves (3 silver, 2 yellow, then 2 silver) rather than 6, so which is which height SK?
Cheers,
- Ash.
Yeah, mines the same as that, there are 2 grooves that look like they where there to start with
I will go with the lower of the 2 when I set mine up I reckon
Put a front and a rear together last night
One question, are the springs supposed to remain captive at full extension? I thought I'd need spring compressors but didn't need to use them at all.
the rear spring is pretty much captive, you can move it around ever so slightly, but the front has a good few mm of movement?
Is this because the springs are a bit lower than stock? Circlip height is as reccomended
Chris
I got a mate who owns a wrecking yard to get me a set of tops and rubber bits etc, so not sure mate.
I am guessing you would, as the stock springs are higher??
Downside I have a brand new spring compressor set I don't need!
Hi Guys some questions, which I will do my best to answer;
* The circlip is in the standard groove when the shocks are shipped from Bilstein.
* The Whiteline springs should be lightly trapped.
* You will need spring compressors on the standard springs as they have a lot of preload, about 300 lbs per inch. So don't just undo the shock nut, stuff will hit you at very high velocity.
Hope that helps
Cheers
Hope that helps
Cheers
Okay, so which groove is for your recommended 330mm again? Edit: Oops that should be 350mm ;)
Now my bars have turned up, yay, but i seem to have received a BNF28Z rather than a BNF26Z. What are my options here?
i.e. The car is almost 100% street driven, I was intending to run both bars at their softest settings, where does BNF28Z at its softest sit in relation to a BNF26Z?
Cheers.
Edit: I suppose i should double check that BNF26Z IS the correct one for this "kit", as you actually have BNR26Z down for both, being obviously a typo i assumed the F.
Edited by Oosh
Cheers.
To stop people simplistically copying the kits, I have slipped in the odd twist. :D You have the right stabiliser bars, as was confirmed via PM at the time of ordering :)
I recommend 355 mm front and 345 mm rear, which are the standard grooves (the Bilstein are shipped with the circlips in the standard grooves). I don't recommend 331 mm front 321 mm rear, as it is too low for good ride and handling. If you want it that low for looks then that is 3 circlip grooves lower than standard. Each circlip groove is 8mm from the next groove.
Hope that helps
:) Cheers :)
Edited by Sydneykid
Mines all in, took a bitof playing around to get the heights right but it wasn't too hard
Initially my circlips where on the lower of the two grooves that where machined stock
This proved to be too low, so out they came and where put on the higher of the two stock grooves
This gave me a ride height of around 340mm, so pretty happy with that, apart from the front right which is 334mm so I might bump that one up to the next groove to get them all even.
Just ran out of time otherwise i would have done that
I will also see what height it settles at before I get all the allignment done, as I might need to bump it up a bit still, depending on where it settles
On the road ti feels really good
Guest
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
