i just got a front pair of these shocks revalved for stiffer springs etc, and they are AMAZING.
ive had japanese coilovers (tanabe) before, ive borrowed my mates cheap and nasty HSDs and now ive got bilsteins, they are so much better than anything else ive had.
both more comfortable and handle heaps better
cant wait to take em out to the track!
Edited by salad
if this group buy is still on can i check the availability of the front Hduty swaybar - BNF28 and the rear XHduty swaybar - BNR26X
is there a kit which includes the bushes and links aswell?
PM sent
:no: cheers :D
Hi sydneykid
im interested in these and can i have sum prices inc shipping to melbourne PM me..
-Front & Rear Springs (im looking to lower my car only 25mm front and rear coz i have 19inch" rims and any lower it will rub. so would u supply lower 25mm springs?)
-Front Bilstein & Rear Bilstein Shocks
cheers
bill
SK i have lowered my car quiet abit...
Center of rim to gaurd on both front and rear is 295mm, and im not exaggerating at all lol
I am goin to grab a few bits off you to go with some whiteline stuff i have (mainly after some traction so adjustin the camber as much as i can), is bein that low going to damage anythin (apart from my kit and exhaust.. hahaha)??? I noticed better handlin when it was 10-15mm higher but i prefer the low look.
Shoot, where to start............just a short list of stuf that your are risking;
1. Drive shaft breakage is possible
2. CV joints will wear very fast (they are also soaking up extra power due to the extreme angles)
3. Steering tie rods (front and rear) are under extreme loads
4. Every single bush in the front and rear suspension will wear out excessively fast
5. The strut towers will eventually crack (both front and rear) due to the lack of bump absortion
6. The rear cradle will crack around the upper and lower control arm joints also due to the lack of bump absorbtion
7. You will suffer poor traction, so it won't stop or accelerate anywhere near its potential
8. The front and rear windscreens are stressed members, so they will eventually crack as well
9. Every electronic component is being subject to higher than its design levels of NVH, so they will eventually start to fail one by one
10. Your chiropractor will make a small fortune fixing your lower back problems
That's pretty much the major items, there are quite a few minor ones of course, but I think you get the drift.
:D cheers :(
Edited by Sydneykid
Alright Gary... whats the lowest i can be without stressing the suspension etc too much?? :O Dont tell me 330mm coz thats heaps hahaha
I use camber correction as the first measuring stick as to how much a car can be lowered. When the camber gets grossly excessive, then you know you have lowered it too far. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
Using that rule of thumb, 340 mm front and 330 mm rear is a low as I would go, keeping in mind that they handle best at around 350/340. So even at 340/330 you are sacrificing handling for looks.
:thumbsup: cheers :no:
Edited by Sydneykid
SK,
will the shocks work on standard gtst springs? and just to confirm that they are height adjustable? what's the advantage of going to the whiteline springs also?
i want something that i can adjust about 20mm lower, but put back to standard if i need to
but i also want the ride to be comfortable as this car probably won't ever see track work
and finally, just confirming that the price is for a pair? so a set of 4 shocks will be around $1140?
thanks,
Warren
Guest
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
