Ok .... what would be the minimum suspension wise you would do??
I've got a front strut bar, and l don't want to lower the car as its a daily driver and already have a "toy" car.
Rear sway bar? and maybe just sub frame alignment???
  • Replies 300
Posted Images
Thanks alex.
Would the caster be really necessary? or would the other two be suffice?
Also when it comes to the fixed & adjustable sway bars, which would be the better to go for? l'm guessing for the small price difference i should go the adjustable?
SK said caster is really good, i havnt done it yet to compare but id say its pretty damn needed (steering is pretty "soft")
i got the adjustables, bt i dont adjust them. But, i think they may be better because they have the more "extreme" settings re stiffness
A few guys have asked me to give them some more details on each part and what it is used for and why it is needed. Here is what I wrote for them;
Shocks and spring are prety obvious, I have chosen the Bilstein shock rates to match the spring and stabiliser bar rates,, So they have good sporty ride, not uncomforatable and still give great handling.
If you are going to lower your car (and who isn't?) you are going to need some camber correction, otherwise you are going to wear out the inside of the tyres. This is due to the excessive negative camber that happens to Skylines and Stageas when you lower them. This is what is needed for each height increment;
Standard (new) height is 380 mm (centre of wheel to guard)
360 mm needs only the standard rear camber adjusters
350 mm needs 1 front camber kit and 1 rear camber kit
340 mm needs I front camber kit and 2 rear camber kits
Stabiliser bars are THE best bang for buck handling upgrade you can do. And you can fit them easily yourself.
Adjustable or not? Pretty simple really, if you want/need to spend the time adjusting the anti roll to fine tune the balance just how you like it and you know what you like, then the extra cost of adjustable stabiliser bars is worth it. But if you just want to put them on and forget about it, then save some money and go the fixed rate bars. I have chosen the anti roll rates (bar sizes) that complement the rest of the kit. So have no fear that they are inferior in some way, because they aren't.
Skylines and Stageas NEVER have enough caster. That's why they wander at speed and understeer on turn in, not enough caster. The 4wd ones are worse, they have even less caster than 2wd versions. They really benefit big time from more caster.
You could leave out the rear subframe alignment kit, but it is only ~$100 and takes 10 minutes to fit. Age softens them and the strandard rear subframe bushes need all the help they can get even when new.
A few guys have asked, no don't make any money of what they buy, I got paid for doing the engineering of the kits. So I don't really care whether someone buys a whole kit or not, I am just letting you know why each component is there in the kit. If I could have left out some parts I would have, but I couldn't.
Hope that answered your questions.
:) cheers ;)
Edited by Sydneykid
Hmmm, I'm just wondering, SK, how long are we going to be able to source parts from this Group Buy? I will probably get at least a Caster kit soon (once all the initial "new car" financial hurdles have been cleared), because I agree that the steering just off centre is a bit "loose" and it doesn't quite self-centre as well as it could. And the stabiliser bar seems to be popular and effective, so that might be a go as well.
Is it a matter of a number of sets or packages being made available, or will this keep going on for a while, and then Whiteline and Bilstein just catering to the demand as and when required?
But as far as changing the shocks and springs (and camber correction, of course)? I'd really like to lower it (haven't checked the clearences yet, but it is up high), but fact is that they are doing a great job at the moment and I seriously doubt they'd need replacement. Turns out it's not going to be my daily driver, but enjoying the car now and the thought of putting it off the road even for a few days, well...
Cheers,
Nick T.
Cheers,
Nick T.
Hi Nick, I thought I covered your first quesion in post #70;
Bilstein won't make Skyline shocks just for Australia, we don't order enough to make it worthwhile them doing a production run. So we have to wait until Japan orders. Nobody knows how long that will take, could be months, might be tomorrow. Plus Bilstein production scheduling is currently 3 to 5 months ahead. So that's the minimum anyway.
If the Bilstein distributor gets enough delivery out of the production run. then I might be able to convince them to do it again. But if they only get a handfull, then they won't want to offer a cheap price. It's a kit deal, so I don't think I will be able to get Whiteline on board without Bilstein.
The bottom line, if you want a set, then order them now, I would much rather SAU guys get them than outsiders. Jamex will hold them on deposit ($100 a shock).
I don't know how else to express it. There are 2 sets of Stagea front Bilsteins left, then that's it, no more Group Buy, for I don't know how long.
Yep, the caster kit is very worthwhile, makes a big difference to turn in, steering feel and straight line stability. They are hard to fit without the right equipment. I did a Skyline caster kit a couple of days ago. Jacked it up, took the wheels off and removed the radius rods. Popped down to Heasmans and they used their 20 tonne press to push out the old rubber bushes and push in the new polyurethane adjustable ones. Took about 20 minutes, would have cost about $30 to $40. Then went back home, rotated the adjusters for maximum caster and then fitted them. Drove it to the workshop and did a quick wheel alignment, the toe needs adjusting when you pull on the caster.
I had the standard springs and shocks in for about 20,000ks, the spring rates weren't too bad but the shocks were terrible, Floated around like a boat. So I slipped the Bilsteins in it, dropped it down a few circlip grooves, still with the standard springs, for about 5,000ks. I was working on the kit at that stage and so I needed to check out the whole thing. I was pleasantly surprised at how much difference the springs made. The comfort is only mildy affected and it has a much more sporty feel.
A few of the guys to save installation costs, have fitted their kits over the weekend and then dropped the car off for the wheel alignment (and any stuff they can't do) on the way to work on Monday. Pick it up Monday night, all done. The Stagea Suspension thread has most of the info you need to DIY.
:D cheers :)
Got a quick query; are the Whiteline springs with this kit (both front and rear) a better buy than say Tein S. Tech Lowering Springs to suit the WGC34? Can anyone comment on this please?
Also, how would the Whiteline front camber set compare to the Tein front Fixed camber kit? Cheers for your thoughts...
Im going to grab some suspn goodies from the original list, just going through all the various options etc....
Brendan
Edited by bwilkeson
Does that mean there are no more rears available either?
I think you mentioned some problems with the rear of your car when you only had the fronts installed.
Hi guys , just picked up my Stag1997 yesterday and came across this terrific site and the group buy- With 120k's on the clock, I would love to get the "lot" but am I too late? I expect to join a number of discussions anyway, as I have RB26 manual conversion in mind and there is a heap of helpful info here. I live in Manly and I see very few Stageas around here! Regards, Rodd.
hey rodd, sounds interesting, ive done the rb26/manual conversion and honestly i would buy a 260rs straight up, the stagea diff is useless, brakes too, engine and box useless obviously, clutch booster is a pain in the bum as u gotta chop a 4" hole in the firewall, and lastly it cost me as much as a 260rs to do mine (though i had plenty more mods like highflow turbos/autronics, twin plate clutch)
just some advice, but if that still makes u wanna do it then feel free to ask any q's and ill try and help :(
260rs is 40K with 80 000km on the clock in perth, wish i bought that to save the hassles, but i had the 26 etc from my previous car.
cheers
Brad
Hey Brad, thanks for the reply; I had thought of the 260 but hadn't seen many at the time I was looking, so let the idea go. Looking at the hassles ahead, if they aren't too time consuming, I'm up for it. I figured that for the money,[a budget of $20000 to 23000 on top of the car] and careful selection of components that Icould get a reasonably reliable daily driver with around 275rWkW's. does that sound possible? I have to say though that it seems alot more complicated than my tuner has told me. How did your conversion go power/performance-wise and would you do it again? Regards, Rod
any updates as to an ETA on these kits SK?
Yep, Skyline and Stagea springs are due today, just waiting on the comfirmation of exactly what part numbers. I will PM all of the guys with outstanding orders as soon as I know.
:) Cheers :)
How long does Whiteline take to make up a set of springs, and swaybars?
Going to do some suspension work over xmas/January.....
Cheers, Brendan
Hi Brendan, stabiliser bars are made to order, which takes about 4-5 working days. Usually they have springs in stock, but I found it hard to guess the Group Buy volumes and mix and they ran out of a few part numbers. Had to wait for the production cycle to go around, usually 3-4 weeks, but this time ended up 6 weeks.
:P cheers :)
Thanks mate, will suss it out in December.
Will definately order the swaybars, might just add a circlip gruve to the KYB shocks I bought, like you have to the Bilsteins, and either use standard springs or (probably) go Whiteline springs.......
Will place and order asap. Thanks.
Brendan
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
