Hey there, it's 1inthefront here. I would like to buy my husband - 3intheback - a rear swaybar for the S2 for his 40th birthday in October.
Is the group buy still on? I cant quite afford front and rear bars, but it seems that to replace the rear is the best place to start.
Thanks for your help, this will put a big smile on his face and also to minimise the impact of hitting 40!
Absolutely, no problems, PM sent with details.
:ermm: cheers :O
  • Replies 300
Posted Images
hey gary, im looking at getting a set of shocks for my stagea, however the rear shockies on my s2 rs four s appear to have the fork style bottoms rather than the eye style that other stageas seem to have, can you get these aswell?
  • 1 month later...
hi SK
your pm box is full.
i received the swaybars but i can't find the pineapples. i thought they might have been slipped into one of the swaybar boxes but it's definitely not there.
in addition are the sway bars supposed to come with new pin rubbers? (the D-rubbers were in the kit)
andrew
Edited by wolverine
hi SK
andrew
PM Sent
:ninja: cheers :yes:
hey gary, im after the 350mm springs, do these also suit my stagea even with the fork style rear struts?
could you please pm me details about payment/part numbers etc.
...cheers Andy
...PS have you put your sideskirts on yet? ...pics???
...cheers Andy
PM sent
:no: cheers :laugh:
Oddly enough, my car ALSO pulls to the left!
Nothing major, but if you let go of the steering wheel, it eventually starts turning left... i presume i just need a wheel alignment?
Both you, alex, AND leshy (terminal) said your cars pull to the left??? so does mine!!! It was more than a year ago since you two posted that, have you got it sorted now???
i just received shocks and coils and the subframe al. kit from SK (thanks greg thats awesome), so will be fitting them when the car comes back from the smash repairs. Did you fix your settings? ill see how i go after having suspension fitted and re-aligned...
  • 3 months later...
as mentoined in stagea discussion i just fitted sk's suspension kit, was really impressed with quality and ease of fitting[bars shocks & bushes] everything went together as it should and the end product is now a comfortable good looking super handling stagea, and no fiddling around to find rattles & squeaks. great product great VALUE, thanks again gary for all your help, leigh
  • 1 month later...
I am off to Bathurst tomorrow for the 12 Hour race, the race team is running (not a Skyline) and I have to do my Team Manager thing. I will be back on Tuesday, so please excuse the slow responses to posts and PM's.
:pirate: cheers :ph34r:
  • 1 month later...
Gary,
When installing the whiteline rear springs - i had to go to the third highest circplip groove on the strut before the spring would even touch the top hat. Is this normal? ie I had to go to the second highest circlip groove to get a better height.
Adrian
think about it
when you only have preload adjustment (which is essentially what it is)
if you want to lower the car, you have to move the spring lower since you dont have a threaded shock body to screw down, and not effect the spring tension.
so yes, it would make sense that it happens...adn will also damage your shocks over time due to reduced stroke travel, they have hte possiblilty to heat up too much from the short strokes.....
After racing dirt bikes for a few years know - i know a bit about suspension setup. Just wanted to know if others had the same setup with the kit. As you can see i from the pic i added to signiture i was going for a standard just lower than standard height setup as i will be towing bikes etc.
Does someone know of a replacement tie rod end to suit the Stagea S1. Think i read elsewhere that some one had used a s14 equivalent. is this true or am i best ordering one thru nissan?? When putting the suspesion in i found one tie rod end with some play (102000km) . Would like to replace this before taking it for a wheel alignment.
Thanks in Advance,
Adrian
Edited by ozktm
the rear uses all s14 rods, diff, adn subframe bushings (if you want the metal ones liek i have)
front uses skyline and s14 stuff...skyline gtr front sway, s14 everything else
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
