  • Replies 300
Posted Images
second that
Fronts are $588... Turns out i dont need mine(already had some in there) So if anyone needs BRAND NEW FRONT STAGEA BILSTEINS in vic, i will deliver them too you.
Cheers
Ryan
Cheers
Ryan
I was just wondering, the old price used to be $486/pair with the SAU discount... is there no SAU discount anymore (ie. group buy finished?)
As far as the PM I got from Matt, all the other prices are still the same. Only the prices for the shocks have changed - I think he mentioned that they're now the same rates as R32 GTR, as they ride better.
  • 2 months later...
Bump for SK or Matt.
Please update us on pricing, for the benefit of all!
Thanks
I'd also like to know if this group buy is still available and is pricing on all the parts the same as the original post?
The original Bilstein shock that was used in the front of the Stagea kits was discontinued not long after I started the Group Buy. So we have been using the Bilstein R32GTR front shock as a base, which actually gives a slightly better result. The downside is they cost $50 more each. I had Bilstein absorb the price increase ($100) for as long as possible to keep the Group Buy prices the same. But all of the suppliers have had multiple price increases since the Group Buy was established over 2 years ago and I can't hold them any more. For the moment the only change is the extra $100 on the front shocks, but there will be an all over price increase of around 5% very shortly. So get in now if you want to avoid it.
A quick reminder, some time ago I did negotiate a price reduction of around $90 in the front camber kit, so the change in the total kit price over all this time is around $10.
For exact pricing on your specific needs, a PM is the best method.
Cheers
Gary
Gary,
When installing the whiteline rear springs - i had to go to the third highest circplip groove on the strut before the spring would even touch the top hat. Is this normal? ie I had to go to the second highest circlip groove to get a better height.
Adrian
Yes, quite normal, I run mine in the top circlip groove.
:( cheers :)
doesnt that mean the shock is too long for the spring?? back when i had my ute i had to get shorter shocks for my lowered springs to keep them held in place. i know having the shock that long wont damage anything, but its more a roadworthy issue. my mate got done by the transport office for havin springs that werent held in place properly.
  • 3 weeks later...
  • 3 weeks later...
Hi SK,
Payment sent. I tried to PM you but it was full.
Any chance of an ETA?
Cheers.
I cleared a bit of space today in the PM inbox after being away for the weekend, first weekend off in 6 months.
Cheers
Gary
I cleared a bit of space today in the PM inbox...
Hi Sk,
I wasn't too concerned about your mailbox being full. I'd think you'd have to have one of the highest contact ratios of any of the members...
But still no luck, your mailbox has been full since your post... :woot:
Just wanted to make sure you'd received my payment for the suspension (see below) and see if there's an ETA for delivery (I haven't heard anything yet)?
02/06/2008
ANZ INTERNET BANKING FUNDS TFER
TO JAMEX AUSTRALIA
$2,364.55
Thanks.
Tee Carter
hay sk
after pricing i have a series 2 2001 rsv 2wd
rear shocks and springs
rear stabliser bar
front caster kit
can i please get ur bank details too
delivery to the gold coast 4215
thanks myles 0432355971
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
