  • Replies 300
Posted Images
Gary,
When installing the whiteline rear springs - i had to go to the third highest circplip groove on the strut before the spring would even touch the top hat. Is this normal? ie I had to go to the second highest circlip groove to get a better height.
Adrian
Yes, quite normal, I run mine in the top circlip groove.
:D cheers :D
adn will also damage your shocks over time due to reduced stroke travel, they have hte possiblilty to heat up too much from the short strokes.....
No it won't, the shock doesn't care what part of the stroke you are using. In a mono tube shock (like a Bilstein) it still holds the same amount of oil, just different amounts above and below the piston.
In a twin tube shock, when you lower it excessively, the excess oil is transferred into the outer tube. This places more oil between the inner tune and the atmosphere. But oil transmits heat better than nitrogen, so the shock would in fact run cooler, not hotter. The temperature difference being so small you would never notice it on a road car of course.
:D cheers :D
  • 3 weeks later...
Hi there Sydney Kid,
I was put on to this thread from a mate as i currently need new suspension for my R33 GTR. Not very mechanicaly minded so alot of stuff here is giberish to me.
So basically can i get a quote to for the best setup you think would be good for my car?
Cheers....
  • 3 months later...
AMEN - I will be ordering the full kit as soon as i get my tax back (10 days and counting)
we know you are busy mate - all respect - just letting you know i am here :thumbsup:
Edited by captinsane
try pm'ing around or start a new thread to see if anyone who has ordered SK's kit in the last while still has relatively good shocks to use left over from an upgrade.
just checked SK's profile guys
FYI
In Topic: R33 Gtr Bilstein & Whiteline Suspension
Sorry for the delay in responding, especially to PM's. The video card in my home PC died and it took me 4 days to find out what it was and fix it. So I am about 110 PM's behind at the moment and trying hard to catch up. Add that to the workload at Superior Suspension (12 to 14 hours a day, 6 days a week) and it will take me a few days to answer everyone.
Hang in there, if you have transferred money, it's safe, I am not going to run off to Brazil with it. You won't miiss out, the Group Buy isn't going to end soon as I have spent some time with Bilstein securing the shock supply for a couple of months at least.
Advanced warning, I am off to the US for 5 weeks from 1st October to 5th November. Checking out some east coast action, Detroit, Chicago, Daytona and the SEMA show in Vegas. So when I don't respond to PM's or emails in that period, I am sure you will understand why.
cheers
just an FYI on his behalf so we know what's going on
we can still order i am pretty sure but i believe SK is under the pump at the moment
Just keep trying to PM him...
I stil can't get though
His last activity on the site was on 24 august so i'd kep checking his profile till it appears that he's been online - then send him a PM and hope that he's seen to some of his Messages :D
Chances are i presume he won't be able to get your order in in a hurry though...
but here is my direct deposit details though in case you want to send ME the money :kiss:
bank
branch
et alia...
I'll send you a lollipop, a paperclip and some spare postage stamps:D
hahahaha
  • 4 months later...
So there l was ... almost ready to order, and now l can't see the excel attachment with prices & bank details anymore! :s
Anyone else got a link to it??? Need to work out how much l need to transfer across.
  • 3 weeks later...
Yes... I have found that some images which have 'disappeared' can be found in his SK's profile - this may or may not be the image you're after:
Stagea_Whiteline_Package
I thought I fixed up all the links in this thread some time ago. Certainly the price matrix is working for me. Anyway, PM me for details and Matt will get back to you ASAP.
Cheers
Gary
    • Z32 AFMs are 80mm tubes. RB26 AFMs are smaller. Just measure. Nismo RB26 AFMs have a different part number to original 26 ones. Probably also have a Nismo badge - but I don't know because I've never been near one. It's unlikely that they've been changed anyway.
    • Hey looking for pointers or experiences with indicator wiring/ common faults for the blinkers on the r31, I have a 87 silhouette and am having dramas with the blinkers staying on (not flashing) to indicate right,while trying to indicate this way the relay makes a constant noise, The front passenger side fender blinker is missing the harness connector to the bulb so is not connected would this effect the opposite side? Both rears work as they should, and blinker that stays on functions normally when on hazards instead of indicating, have replaced all bulbs,fuses and relay Cheers
    • I’ll check the AFM’s and confirm. I’ve seen on another forum post years ago it’s identified with an orange sticker and larger diameter. Unsure if I can check the diameter without removing the air filter. Is there a way to identify if the AFM is stock? I’ve done a quick search and it looks like it might be a green sticker instead?   Will try check that turbo core tag. Looks like a very tight fit in there. Do you know what number would show if it was a stock T25 turbo?
    • The car and the 33GT-R wheels look great. I can't remember if spacers were needed for these but the offset looks perfect for the GTS25t.
    • And the lack of ubiquitous availability. If it was less likely that I'd run out of fuel while trying to cross the crime zone, I'd probably be all over it.
