  • Replies 300
Posted Images
i have teh exact same problem with the fronts springs...
they are much too wide for the lower spring seat.........
hence i thought someone put the wrong spring seats with the shocks... because the rear seat fitted much better with the front springs.......
Thanks to Burns we have identified what the problem is. Some kits were sent out with 83139 springs instead of 83159. The 83159's are in stock at Whiteline, so the turn around will be quick. PM me and I will arrange for a replacement set (83159) to be sent out and the 83139's picked up and returned.
Sorry, I appologise for the incorrect supply.
:D cheers :(
Edited by Sydneykid
  • 4 weeks later...
Alex, your stuff is ready to ship, PM sent.
:rofl: cheers :rofl:
PS; One of the guys has found his Stagea to be a bit low even with the lower spring seat circlip set on the highest position. Since we have all sorts of specifications with double sunroofs, substantial sound systems etc, all subsequent Bilsteins have been machined with 3 extra grooves to give additional height if required.
If you find yours is a bit low for your requirements you can either return them and I will have Bilstein add the extra grooves. Or you can have your local suspension/machine shop do it. It is fairly simple, they are 1.5 mm grooves, 0.6 mm deep and with 8 mm between them.
Under no circumstances should the springs be reset, higher circlip grooves are the best and cheapest method for achieving the extra height you want.
Sorry for any inconvenience.
:spank: cheers :spam:
Edited by Sydneykid
Are circlip grooves legal? Compared to say, adjustable coilovers?
Circlip grooves are a standard fitment, lots of shocks use circlips to retain the lower spring seat. Many new cars come with circlip grooves, for example any of the Subarus equipped with Bilsteins (B4, STI etc ) have circlip grooves.
I have had 20 or so cars checked for initial rego with screw spring seat height adjusters and none of them have had any problems either. It's more a matter of legal height, than how that height is achieved.
Let's face it, aftermarket mud flaps are technically "illegal", so are non standard spark plug gaps. It all depends on how fine a line you want to draw.
:) cheers :spank:
Edited by Sydneykid
SK, do you have any caster kits left? After the drive down to Canberra and back, I'd really like a set as the wandering started to get on my nerves after a while...
Yep, Whiteline have them in stock usually. I was pleasantly surprised at how much difference the extra caster made on our Stagea. Takes that dull feeling out at straight ahead and adds a bit of weight to the steering. Not a lot, but enough to feel like you are in control.
Just PM me to start the ball rolling.
:P cheers :P
Yep you will need a press to push the old rubber bushes out and push the new ones in. They are a tight fit. It would probably be easies to take the car to a suspension place to have them fitted as you should get a wheel alignment done after fitting them any way.
  • 3 weeks later...
Anyone want to Buy my white line sway bars, they have only been used for about 3 or 4 months, excellent condition. Selling them as I'm selling my car.
$350 Posted  Any takers?
PM sent.
  • 3 weeks later...
  • 1 month later...
There are a few sets of Bilsteins left so it not too late ot join in on the Group Buy. Just PM me if you have any questions, or post them here.
:) cheers :P
Hi Gary,
Id like to order a set of the following suspension components, including SAU discount and freight discount, if that is still possible?
* Stabiliser bar, front, 24mm adjustable, BNF27Z $219
* Stabiliser bar, rear, 24mm adjustable, BNR11XXZ $219
* Caster, front, KCA331 $110
= total of $548 including freight, delivered to Adelaide?
Cheers, Brendan
Edited by Tangles
Received my items today, with thanks to you Gary.
I do however have a question regarding my next suspension purchase; I have no want or desire to 'lower' the car (hard enough getting into the car as it is being so tall and with bad knee pain).
If I was to lower it at all, it'd be like by a bees-dick, maybe just to sit the nose of the car over my new R34 GTT 17inch mags (being fitted in a few days time with Hankook K104 235/45/17 tyres).
Can the Bilstein shocks be used with the Standard stagea springs?
Also, I gather then its a waste of money to buy a front and rear camber kit set if Im not going to be lowering the car?
Ta, Brendan
Ta, Brendan
Hi Brendan, I used the standard springs with the Bilsteins shocks for several months. I also had the stabiliser bars and caster kit fitted at the same time for a very acceptable ride/handling balance. My Stagea was nose up when it arrived, and I used to get the “it’s very high” comments. So I lowered the front 20 mm using the extra circlip grooves and left the rear as it came. I didn’t get any “its low” comments, but the “it’s high” comments stopped. It didn’t need any camber correction at that height, the standard rear camber adjusters had just enough.
:laugh: cheers :D
:laugh: cheers :D
Awesome, thanks heaps for that information.
Im going to order a set of front and rear Bilstein shocks then, and the sub-frame alignment to finish it off. I shall send a PM to you when I order those products; got to chat to the wife first.
Thanks very much for your continual advice to myself and other Stagea drivers, Im sure.
Brendan
  • 1 month later...
Check out the thread on the differences between a bad shock and a good shock for more information.
http://www.skylinesaustralia.com/forums/in...howtopic=114718
:( cheers :)
Edited by Sydneykid
    • Took it to all Japan day. Thrashed it all day and it will still drive home. Very very happy man right now
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
