how are you people? i was wondering what your thoughts would be on drifting a r33 non turbo with a completly std motor but going all out on the suspension lsd and so fourth?
has anyone done this i cant have a turbo because of the new restrictions in nsw thanks!
it would be a rb25de type s
Edited by future1
https://www.sau.com.au/forums/topic/85611-na-drift/
I have an n/a rb25 de cefiro with teins and lsd yes it is possible.
a mechanical diff would make it easier it drift ok remeber the ae 86's are n/a I'm a great believer that suspension is more important than power when drifting
cheers
meggala
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1549325
agree with meggala... but power does make it easier unless your willing to commit to the corner.
i've attempted a few "powerslides" with clutch popping - can't say is the healthiest thing...
take note that 33's are heavier than the 86.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1549529
you could do it. i used to have an old R31. it was only a single spinner diff, and my spare tyre was a rock hard compound. when i wanted some sideways action, i put that tyre on the driving wheel, and drifto!
the R33 gts coupes aren't that heavy, about 1300kg (i think). with the suspension and diff you have, just put some really sh1t tyres on the rear and hang on! some basic power increase mods would be good as well, like a pod and an exhaust.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1552807
it is possible ive got a mate who drives an NA silvia with shitloads of suspension work done and he can drift aswell as a turbo car...
as Eug said you just have to commit yourself to the corner and use proper technique rather than just power on mid corner and hang the tail out as i have seen some people do.
i drive a turbo R32 and the power just makes it easier to hold the tail out.
but it is very feasible to make an NA car drift well.
good luck
Mitch
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1554556
Nah their not heavy at all mines only at 1150Kg according to my rego.
your rego is wrong :(
unless you have the model with the RB20E?? doubt it would make 170kg difference though.
they weigh 1320kg stock. i have had this confirmed on a weighbridge.
you can definitely drift a n/a in the wet (or so i'm told...), as for the dry i'm not game to try it on the roads and haven't found time to take it to the track.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1556648
My partner can make our whale drift, much to my surprise, on dry roads too, scared the crap out of me (boys will be boys!! :P ). I didn't think it would of had the power to drift, although it has had quite a bit of suspension work done, a button clutch, LSD added, and making 112rwkw.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1557427
Were you planning on learning to drift with this car, or trying to compete with it?
If you're only trying to learn and maybe run in some low level comps, then you can "drift" anything. I used to get my old Volvo sideways, and that thing was a dead stock auto.
They weren't the most elegant drifts and I wouldn't try linking all of Wakefield Park together in it, but for the EC skid circuit (I haven't been out to Driftland yet so I can't say) it would have been fine wet or dry.
It certainly taught me the basics of countersteering, and balancing the car on the throttle / brakes.
If you wanted to get into some serious competition events you may want more power and torque than what a stock RB25DE is going to offer you.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1568192
I used to drift mine everywhere, uge can back this up wet or dry, and as he said you had to comit to the corner, alot harder in an underpowered car but more then possible..
The original diff was the best... till i smashed it, and none have since compared... the last 3 have been turbo ones but they didnt lock up as well as the original... i now have a nismo 1.5way mechanical.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1568300
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
