how are you people? i was wondering what your thoughts would be on drifting a r33 non turbo with a completly std motor but going all out on the suspension lsd and so fourth?
has anyone done this i cant have a turbo because of the new restrictions in nsw thanks!
it would be a rb25de type s
Edited by future1
https://www.sau.com.au/forums/topic/85611-na-drift/
I have an n/a rb25 de cefiro with teins and lsd yes it is possible.
a mechanical diff would make it easier it drift ok remeber the ae 86's are n/a I'm a great believer that suspension is more important than power when drifting
cheers
meggala
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1549325
agree with meggala... but power does make it easier unless your willing to commit to the corner.
i've attempted a few "powerslides" with clutch popping - can't say is the healthiest thing...
take note that 33's are heavier than the 86.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1549529
you could do it. i used to have an old R31. it was only a single spinner diff, and my spare tyre was a rock hard compound. when i wanted some sideways action, i put that tyre on the driving wheel, and drifto!
the R33 gts coupes aren't that heavy, about 1300kg (i think). with the suspension and diff you have, just put some really sh1t tyres on the rear and hang on! some basic power increase mods would be good as well, like a pod and an exhaust.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1552807
it is possible ive got a mate who drives an NA silvia with shitloads of suspension work done and he can drift aswell as a turbo car...
as Eug said you just have to commit yourself to the corner and use proper technique rather than just power on mid corner and hang the tail out as i have seen some people do.
i drive a turbo R32 and the power just makes it easier to hold the tail out.
but it is very feasible to make an NA car drift well.
good luck
Mitch
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1554556
Nah their not heavy at all mines only at 1150Kg according to my rego.
your rego is wrong :(
unless you have the model with the RB20E?? doubt it would make 170kg difference though.
they weigh 1320kg stock. i have had this confirmed on a weighbridge.
you can definitely drift a n/a in the wet (or so i'm told...), as for the dry i'm not game to try it on the roads and haven't found time to take it to the track.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1556648
My partner can make our whale drift, much to my surprise, on dry roads too, scared the crap out of me (boys will be boys!! :P ). I didn't think it would of had the power to drift, although it has had quite a bit of suspension work done, a button clutch, LSD added, and making 112rwkw.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1557427
Were you planning on learning to drift with this car, or trying to compete with it?
If you're only trying to learn and maybe run in some low level comps, then you can "drift" anything. I used to get my old Volvo sideways, and that thing was a dead stock auto.
They weren't the most elegant drifts and I wouldn't try linking all of Wakefield Park together in it, but for the EC skid circuit (I haven't been out to Driftland yet so I can't say) it would have been fine wet or dry.
It certainly taught me the basics of countersteering, and balancing the car on the throttle / brakes.
If you wanted to get into some serious competition events you may want more power and torque than what a stock RB25DE is going to offer you.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1568192
I used to drift mine everywhere, uge can back this up wet or dry, and as he said you had to comit to the corner, alot harder in an underpowered car but more then possible..
The original diff was the best... till i smashed it, and none have since compared... the last 3 have been turbo ones but they didnt lock up as well as the original... i now have a nismo 1.5way mechanical.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1568300
    • Shove more foam in it as a minimum if you possibly can. Or steel wool (not the stuff with soap on it!) Baffles / getting the oil out of the air is huge, and should be done at both the cam cover, and the catch can.   I'm about to do a power steering reservoir, and even that needs some thought to make sure air is separated from the oil, to stop evil Cavitation. I'll probably look at doing my own catchcan later on too.
    • I was once told, who it was I'm to old to remember, that the length of the OEM wheels brace supplied with a vehicle is designed long enough for a average person to apply enough torque to do up, and undo the wheel nuts to the specified torque  What a average person is is anyone's guess though, i.e. average fat bastard, average knuckle head, average perfect sized human......like me Unless of course, a tyre shop has ugga dugga'd them up to "torque to yeild/strip" specs, used cross threading as natures lock tight, or a big breaker bar was used to tighten them up to get some nice stretch in the poor old wheel studs Me, I torque wheel nuts to 1 elbow joint click, lower torque settings are based of wrist clicks, higher torque settings are based of shoulder clunks, or total dislocation for anything that requires all of the torques
    • I think the catch can design is pretty flawed. Evident in the fact that the V2 one moved to a larger top mounted filter which alone would have helped with overflow and reduce restrictions compared with the side filter. I also imagine there was a major improvement to the baffling design. It is worth mentioning that this catch can with the RB20 was never as much of an issue and the high kms RB25 is likely a part of the problem. I have gotten quotes for both a new "Vibrant Gen 3" catch can and to modify this existing ones but that may have to wait until after the track day. I hope the sump/head breathers/drains and cam splash plates will be enough
    • Yep, both. The ratio is 1.8 instead of OEM being 1.7. The rocker bodies are modified with a larger bolt hole and re-threaded with 10mm holes instead of the 8mm YT has stock. Finding out they don't actually fit the stock castings cause a lot of un-impressment by the person in the USA who tapped the new holes for the 'upgraded' YT product. He was very unhappy with them given their previous design did not require 'clearancing'
    • That too, but I think this is why she's put the work into the cam cover baffles. I mean, a catch can should only need to be a catch can, not an oil air separator also. Not to say that putting the effort into having it do a better job of oil-air sep is a waste of time, but doing the sep earlier is always going to make life better. And that should happen now anyway.
