how are you people? i was wondering what your thoughts would be on drifting a r33 non turbo with a completly std motor but going all out on the suspension lsd and so fourth?
has anyone done this i cant have a turbo because of the new restrictions in nsw thanks!
it would be a rb25de type s
Edited by future1
https://www.sau.com.au/forums/topic/85611-na-drift/
I have an n/a rb25 de cefiro with teins and lsd yes it is possible.
a mechanical diff would make it easier it drift ok remeber the ae 86's are n/a I'm a great believer that suspension is more important than power when drifting
cheers
meggala
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1549325
agree with meggala... but power does make it easier unless your willing to commit to the corner.
i've attempted a few "powerslides" with clutch popping - can't say is the healthiest thing...
take note that 33's are heavier than the 86.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1549529
you could do it. i used to have an old R31. it was only a single spinner diff, and my spare tyre was a rock hard compound. when i wanted some sideways action, i put that tyre on the driving wheel, and drifto!
the R33 gts coupes aren't that heavy, about 1300kg (i think). with the suspension and diff you have, just put some really sh1t tyres on the rear and hang on! some basic power increase mods would be good as well, like a pod and an exhaust.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1552807
it is possible ive got a mate who drives an NA silvia with shitloads of suspension work done and he can drift aswell as a turbo car...
as Eug said you just have to commit yourself to the corner and use proper technique rather than just power on mid corner and hang the tail out as i have seen some people do.
i drive a turbo R32 and the power just makes it easier to hold the tail out.
but it is very feasible to make an NA car drift well.
good luck
Mitch
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1554556
Nah their not heavy at all mines only at 1150Kg according to my rego.
your rego is wrong :(
unless you have the model with the RB20E?? doubt it would make 170kg difference though.
they weigh 1320kg stock. i have had this confirmed on a weighbridge.
you can definitely drift a n/a in the wet (or so i'm told...), as for the dry i'm not game to try it on the roads and haven't found time to take it to the track.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1556648
My partner can make our whale drift, much to my surprise, on dry roads too, scared the crap out of me (boys will be boys!! :P ). I didn't think it would of had the power to drift, although it has had quite a bit of suspension work done, a button clutch, LSD added, and making 112rwkw.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1557427
Were you planning on learning to drift with this car, or trying to compete with it?
If you're only trying to learn and maybe run in some low level comps, then you can "drift" anything. I used to get my old Volvo sideways, and that thing was a dead stock auto.
They weren't the most elegant drifts and I wouldn't try linking all of Wakefield Park together in it, but for the EC skid circuit (I haven't been out to Driftland yet so I can't say) it would have been fine wet or dry.
It certainly taught me the basics of countersteering, and balancing the car on the throttle / brakes.
If you wanted to get into some serious competition events you may want more power and torque than what a stock RB25DE is going to offer you.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1568192
I used to drift mine everywhere, uge can back this up wet or dry, and as he said you had to comit to the corner, alot harder in an underpowered car but more then possible..
The original diff was the best... till i smashed it, and none have since compared... the last 3 have been turbo ones but they didnt lock up as well as the original... i now have a nismo 1.5way mechanical.
https://www.sau.com.au/forums/topic/85611-na-drift/#findComment-1568300
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
