hey guys got a few bits for sale at the moment :D
gtr stock low mount turbos rebuilt with larger front and rear wheels, and also steel exhuast wheel, capable of around 400hp at wheels (i made 350rwhp on 17psi with basic engine combo and stock internals so i couldnt wind up the boost anymore)
done less than 1000km since rebuild with receipts :)
$1600 ono (rebuild and highflowing alone cost $2500)
gtr coilpacks - $60 each
gtr injectors (x2 only) - $50 each
gtr ignitor pack - $120
gtr engine sump/diff complete $400
bosch 044 external fuel pump as new cond - $250
gtr fuel rail - $100
gtr fuel regulator - $50
gtr r32 intercooler polished, good cond - $500
gtr rear hicas steering rack - $100
gtr air con pump - $80
rb26 oil pump - $100
gtr cams - $200
3" mild steel dump pipes and front pipes to single 4" (no cat included) - $400
cheers
Brad
hey guys
well ive sent J4H012 a PM :D
and no i dont have a starter motor sorry
and lwells, im not 100% sure on specs, the receipts have a part number 04431876-88 nissan turbo x 2
they do have 360 degree thrust bearings, and steel wheels and highflowed to nismo specs is what the shop said.
Dynamic Turbo services did the rebuild which is an Australian wide company.
thanks
Brad
will the dump and front pipes just bolt on to the standard turbos? any pics? and who will pay freight? any idea how much?
thanks
ok front dumps fit stock turbos no problem, they are single 3" design (not seperate wastegate pipe, etc) and ill take some pics today and post them here in an hour or so
buyers pay postage, ill try and find out cost :O
cheers
Brad
  • 3 weeks later...
    • Por que no los dos? At least my euro brawler is reliable - unlike the JDMs I've had. Sheraaz you look familiar, did you ever come to an SAU VIC meet aaaaaages ago?
    • Drove to Cape Schanck to try to get a nice clear southern view over the ocean to see the lights a couple of days ago... instead got crappy cloud cover. Photo of a diorama of Hong Kong street scene. Taken on an iPhone 13 Pro Max.
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
