Hi Guys
I am in the process of changing my sterring wheel but I do not know how to plug my horn.
My setup:
R32 GTST
HKB bosskit Model 115 for R32
Momo APache steering wheel
OK here goes. There is a black wire that has an L shaped end and the red wire that is flat in shape. On the bottom left is a plug that is plug in color.
So how do I plug the horn connectors ???
  • 3 months later...
What I found out in the end the black cord connector gets cut and then u left with wire.
The red cord plugs in
Black cord goes between the steering wheel and the boss kit.
Only problem Hicas comes on after 10 minutes. Getting the car balanced anyway so makes no difference
dAVE pics might help.
When I removed the origonal wheel a black wire is attached to the horn button that fits onto the base of the lead with the white Hicass plug on it. The lead with the white plug also comes away with the origonal wheel. The Boss kit provided a new lead toplug into where the old one once was. Anyway this now provides one terminal to go onto one of two connectors on the MOMO horn switch. Neither seem to do anything.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
