Hi guys, just pulled down my rb20 in my gts4 and had a check of the bore. The bore is pretty much beyond repair unless alot of oversizing is done to it.
Now my problem is, its been hard finding a replacement gts4 rb20 motor for it, i have been told, but not too sure that i am able to use the gtst motor but there is a few things that need changing?
I am just after the list of things that need changing to the gtst motor which will let me run it in my car if this theory is true.
Thanks for any help in advanced..
Cheers
Edited by 510RB
https://www.sau.com.au/forums/topic/85637-using-gtst-to-replace-gts4-motor/
