Item: 1995 Nissan Skyline GTST coupe
Item Condition: Not so great :D
Reason for Selling: Don't have the time or money to fix her up.
Price and Payment Conditions: First offer over $10,000
Extra Info:
Suit buyer with some time to give this car some TLC :)
- Burgundy in Colour
- Apexi N1 Exhaust
- Will throw in a set of 18inch Wheels included (No rubber)
- Engine Rings worn
- Paint in fair condition (Keymarks on most panels)
- Still runs and has rego
- 160k kms
Contact Details: 0413 309 259 Lozz
Edited by GTR-80Y
https://www.sau.com.au/forums/topic/85755-fs-95-r33-gtst-10000-ono/
Rings are worn and did leak some oil from the intake somewhere. Also blows the dipstick out occasionally.
Car still runs good, my mechanic says the engine has some life left but will require a rebuild or swap in the future.
Yes brad the beast is for sale, even wit the engine probs i still think it would run another 13.4 sec pass. ;)
Item Condition: Not so great ;)
Extra Info:
I would assume this is a contact number :D
Cheers
Ken
Indeed it is Ken. lol
Just to let those interested know i've had a pretty firm offer of $9,000 and an unconfirmed offer of $10,000
Car will be in this weeks thursday trading post and has already got a great response from the initial online trading post ad.
So be quick would love to get this over with before the tsunami of calls on friday.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
