Thanks Dennis , it looks like a major engineering feat dosen't it ............
Seriously though for about 1/4 - 1/3 of the weight of a DR30 radiator the R32 GTR one offers probaby 40% more cooling capacity , remember those cars made nearly 280Hp standard in a mild state of tune and do not overheat .
Recently some mental giant wanted to argue the toss over copper vs aluminium as a heat sink medium for radiators , I will agree that copper has the legs on ally but remember this important fact . Copper radiators ares stuck together with solder which has a high lead content and you guessed it - lead is a very POOR conductor of heat energy . Most would say "so what , the tanks are soldered on the core end plates" . They would be right but how do they think the gills are stuck to the tubes ? right again with our poor contucting solder . You could say this fin to tube insulation is a great way to drop heat sink efficiency - but it was a cheap way to manufacture radiators for a long time .
Aluminium rad cores are furnace brazed and transfer heat in the water tubes to the gills much more quickly and efficiently , there is less resistance to airflow through these later cores so its a win win situation .
Cheers A .
Edited by discopotato03
Cheers  A .
Mate,
You got me, I'm going to buy a BRAND NEWIE for my PNV, as I have the DR thermo fans I'm going to mount them on the back and dispose of the motor driven fan mounted on the water pump.
For a few minutes of stuffing around, I'm gunna have the best.
Gotta mean somethin in the power gain dept.
To quote an old friend that used to race Toyota Celicas when he found the all metal GT bumpers vs Ozzy LT rubber/metal were 5kg lighter "It's gotta mean somethin"
Cheers,
Dennis
My Bluebird also used the DR30 fans and shroud but it was not by choise . I would never remove a viscous hub engine driven fan particularly on a turbo car . These fans force feed air through the engine bay keeping the underbonnet temps down which is important with red hot hair dryers lurking within .
All thermo fans do is dump hot air in the bay when the water temp is already a bit high . They'll never move as much air as the conventional one can . Incidentally the viscous hub takes the load off the engine when things are nice and cool .
With thermos the water thermostat is not the only temperature control device and it should be , as I said the fans only come on when EVERYTHING is hot .
If you still think the power loss is significant use a larger water pump pulley ie L20B or FJ20, if its running constant high revs the water pump will be cavitating anyway so kill two with one .
Cheers A .
P.S All RB powered Skylines use an engine driven fan , the GTR fan itself would be better than the 22 yr old L series wind mill - RB26's red line at 8000 , nuf said .
Cheers again .
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
