My cousin will be coming back to Australia to study and he is planning to bring over his rx-7 series 6. He owned it for 3 years now. For all those who had gone through the process, how much did you pay for the compliance? Do you have to use a RAWS workshop? And approximately how long will the process take? Thanks a lot!
the compliance that have been done to cars coming to melbourne has been between $1000 and $1500.
Basically you don't have to meet the strict "only stock models" compliance that you go through under SEVS, so its just a matter of things like:
changing seat belts
emissions placard
tyre placard
fuel filler restrictor
side rear view mirrors
side intrusion bars
cat converters
or other things it may need to meet ADR's. You basically need to get an Engineer to sign for your car and its up to their discretion what you need to meet ADRs, so this means your requirements will vary from state to state and from engineer to engineer. Its best to talk to one that's local to where the car will be registered, and they should be able to give you an approximate quote. Its pretty much like 15 year old import compliance, but usually even more leniant.
IF YOU'RE IN SYDNEY HELLBOY, WE CAN TAKE CARE OF THIS FOR YOU FOR BETWEEN $800 AND $1500 INCLUDING IMPORT PLATE & BLUE SLIP.
MORE ACCURATE PRICE IF YOU CAN GIVE ME MORE INFO ON THE CAR
:ph34r: TECHNICALLY THE CAR HAS TO BE STOCK BUT WITH PERSONAL IMPORTS A LOT OF MODS CAN BE BYPASSED BASED ON "STATE" REGULATIONS.
TELL YOUR COUSIN TO APPLY FOR A PERSONAL IMPORT APPROVAL, THAT WAY YOU WON'T NEED AN ENGINEERS CERTIFICATE. NOT IN NSW...
WHEN WE DO THE JOB AND ARE GIVEN ALL THE DOCUMENTS FROM THE CUSTOMER, THE COMPLIANCE PROCESS TAKES 4-5 WORKING DAYS.
We can do personal imports like the series 6 for around $500 at worst if belts are ok and cat fitted, an R33 passed the other day at the pits with no cat.
Stickers are $16, filler neck $80 fitted, seat belts are same as in RX7 but if VW on tag not just V will be ok, side intrusion bars fitted, cat can be after market but the burn out quick but fitted in Japan so will be ok.
Sign off and a few other checks, in some states engineer sign off is required but call around and contact local transport section asking who is approved to certify.
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
