So after dyno'ing my pretty stock car @ 158rwkw. Im wanting upgrades :D
So been reading and looking at HKS ones they seem pretty good.
Whats the difference between that and say the CRD ones?
The pipe goes over or under for the HKS/CRD ones?
What other ones are avaliable?
Leaning towards getting a japan ready made one.
https://www.sau.com.au/forums/topic/85769-intercooler-questions/
indeed ARC make very good coolers, but there is always the ongoing bitching discusion on using the stock pipe route will create more lag. I think it comes down to personal preference and do you want less piping and better throttle response?
I just got a cooler put on, it doesnt use the stock pipe route, it goes up and over the engine. No omplaints, and i can noticed a lsight increase in power. Need dyno to see what im making.
Good luck!
AVO also do a kit that uses the stock pipes. One advantage of this is that you don't need to cut a hole for the outlet pipe. @ $1430
The main advantage is that the outlet from the cooler is not being heated by the hot air from the radiatior.
There is a lot of info on their website.
http://www.avoturbo.com/construction.html
ARE are a manufacturer who also have heaps of info.
http://www.are.com.au/feat/techtalk/intecoolersMR.htm
Hmm.... Still comes down to the brand vs non branded debate.
I had a friend's bros skyline where the piping went over the engine and the fan and the blate nicked the piping and it cracked the engine and broke it up.
Yeah i have the same piping setup on my R34 and all
you need to do when doing this set up is to trim the fan blades
enough to clear the pipe and there will be no problems whats so ever
once done right. Plus this set up, i think myself is a nicer way of displaying
the pipes and also it gives some detail/looks in the engine bay.
Good Luck
Yep fitted my fake Hybrid cooler on the weekend it took me ages cos I was doing it myself but it was well worth can feel the extra power straight away and you can hear the difference. Just need to get a fuel controller cos with standard ecu car runs heaps rich and guzzles fuel. But apart from that for like $600 for the kit and no cost for labour i am very pleased. :rolleyes::)
Edited by LANFOH
If you have not done turbo back exhaust yet, then I would do that before doing a FMIC.
I put on the justjap cooler.
Now pushing a solid 0.7 bar up to red line.
Can you please explain more on that turbo back exhaust.
How much would that set me back?
I already have an aftermarket exhaust. HKS Super Dragger. Is that it?
noticed on mine that the split dump systems allowed the car to rev out quite alot easier and definately increased power.. if you still have the stock dump pipe down to the Catalitic convertor then i would invest in a new dump pipe for sure...
something like this :
$450 i think from UAS
Edited by Craved
To get the most out of a turbo back, you will need to upgrade the cat converter too.
Note that fitting a dump/front pipe is a fairly labour intensive job - especially if the screws joining the turbo to the stock dump have rusted over (which they probably have).
But the differences in pressure drop between a branded and non branded seem to be rather significant?
On another note, don't just go for the biggest FMIC you can (ie 600 * 300 * 76), as lag is our enemy.
its one of those things where the lingo gets confusing...
dump pipes are really the first part of the exhaust that the turbo bolts onto. this part is where there are usually 2 pipes that join a bit further on in the pipe. one is smaller, for the wastegate, and one is larger for the turbine exhaust gasses.
here's a pic for a r32 gtr:
the dump pipes or 'extension' pipes bolt on to the 'front' pipe.
front pipe comes after the dump, and before the cat.
heres a pic, also for r32 gtr:
the pic CRAVED posted is a dump and front pipe all in one.
it shouldn't matter if its 2 or 1 piece and will differ from car to car, make to make.
hope that helps
dan
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
