Wrecking R33 Coupe
  • Replies 50
- I'll have to look for the hand brake cable & lever
- I will sell the clutch and brake pedals with their brackets/assembly as one piece each. I wont be able to sell the pedals seperatley to the housings. I will take $150 for the clutch pedal assembly (Includes master cylinder) and brake pedal assembly also for $150
Let me know.
Cheers.
Hi all,
Its been a bit hectic getting back to all of your pm's & e-mails, but I'm almost there.
Pm's & emails have been sent to you.
Keep your enquiries coming through. Sometimes it may take a couple of days to get back to you on a particluar part, as they are not all locvated in the one location.
Cheers all
SJ
Hi all,
The only body parts/panels I have left are as follows;
1x Complete Drivers door (including mirror, door trim, switch panel, etc in white) $450 obo
2x rear qtr Glass windows, $50 each obo
1x factory rear windscreen (Window wiper version) $75 obo
I also have the following (and maybe some more, I will have to check)
1x Airbag steering wheel and complete column (with windscreen & indicator levers), $225 obo
1x Complete rear seat, $150 obo
1x Right hand rear tail light (White), $75 obo
1x Rear Bumper bar support, $make me an offer
I will go through the remainder of my parts and list them a little later. For all of you guys out there after the brakes, I do have them, but I will not post a price until I can confirm if I have all of the parts, as i have used parts of the suspension.
Cheers all,
SJ
  • 3 weeks later...
 Share
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
