  • Replies 50
- I'll have to look for the hand brake cable & lever
- I will sell the clutch and brake pedals with their brackets/assembly as one piece each. I wont be able to sell the pedals seperatley to the housings. I will take $150 for the clutch pedal assembly (Includes master cylinder) and brake pedal assembly also for $150
Let me know.
Cheers.
Hi all,
Its been a bit hectic getting back to all of your pm's & e-mails, but I'm almost there.
Pm's & emails have been sent to you.
Keep your enquiries coming through. Sometimes it may take a couple of days to get back to you on a particluar part, as they are not all locvated in the one location.
Cheers all
SJ
Hi all,
The only body parts/panels I have left are as follows;
1x Complete Drivers door (including mirror, door trim, switch panel, etc in white) $450 obo
2x rear qtr Glass windows, $50 each obo
1x factory rear windscreen (Window wiper version) $75 obo
I also have the following (and maybe some more, I will have to check)
1x Airbag steering wheel and complete column (with windscreen & indicator levers), $225 obo
1x Complete rear seat, $150 obo
1x Right hand rear tail light (White), $75 obo
1x Rear Bumper bar support, $make me an offer
I will go through the remainder of my parts and list them a little later. For all of you guys out there after the brakes, I do have them, but I will not post a price until I can confirm if I have all of the parts, as i have used parts of the suspension.
Cheers all,
SJ
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
