As topic and description. I need a new motor. I'm interested in getting a Fj20 non turbo motor that i've sourced for a great price, i can get a top mount turbo manifold for cheap too, will my L20et turbo bolt up? What needs to be done if anything?
Also, will a RB series or L series gearbox bolt upto a fj20? Do i need a different bellhousing?
I was thinking of even maybe setting up a fj20 with sidedrafts :-P
regards, George
https://www.sau.com.au/forums/topic/85798-l20et-or-rb20det-turbo-onto-fj20/
T3 on L20a too small , plenty have turbocharged NA FJ's - you need to use a modern turbo with emphasis on turbine flow and response . This style of turbo will make more power for less boost (remember its airflow not pressure that gets the job done) and the extra CR pulls up the bottom end/consumption/throttle response .
Side draught FJ's are noisy expensive and very thirsty - cop bait too . EFI is way to go . You can always look into KA24DE's - easier to get bits for and no under bucket shims . One timing chain and the local Navara version uses 8.4 CR pistons . Bellhousing style is SR20 so gearboxes a cinch . North south inlet manifolds came on US S14 240SX . Jim wolf Technology does all the aftermarket goodies . 2.4 litres = torque .
The L20ET & FJ turbo's were identical in fittment, just the FJ has a .63 rear housing as opposed to L20 .48.
I'm putting the larger FJ turbo on my L20eT just for now.
Disco,
How much better is a VG30 turbo to the FJ T03, as I'm looking into an L28 for the PNV down the track a bit.
cheers everyone!
Adam RSX: 45mms or? I jsut helped a mate sidedraft his 2.0L Rebuilt Rally Pinto Motor for His mk5 S Cortina. It is horrible to get running correctly. What a absolute pain in the ass.
Ghostrider those vg30 turbos kick ass on rb20dets :( So should be amazing on a L or FJ
Ghostrider the VG30 BB ceramic turbo can be looked at as an RB25DET one with a fair bit larger ARR turbine housing and slightly (tiny bit) smaller compressor and ARR cover . They are drying up fast as someone (red face) let the world know how handy they are . You could use the VG30 item on an L28 easily enough , or use its all important exhaust housing on the RB25 ceramic BB if the L series can support 180-200 Kw . If you could find one another option is the R34GTt turbo as I believe its compressor and cover is slightly larger than the 25DET's cartridge . These made Rb26DETT (206Kw) power from 2500cc but with infinitely variable cam timing . From what I see I think the large ARR VG30 turbine housing with the R33 or 34 cartridge is the limit for these Hitachi ceramic BB turbos . Of these only the series 1 R33's used an aluminium compressor wheel , the later 33/34 used some form of plastic or composite material which generally lets go before the ceramic turbine if over reved . I'd be keeping it down to about 10 lbs boost for reliability - not too foul with 2760 odd cc's .
Sorry to get O/T , much better design than the FJ's Garrett T3 with Nissan exhaust housing . Low friction ball bearings and much lighter turbine , just not a high speed capable turbine .
Cheers A .
I forgot to add if you must use the FJ style T3 I would get it rebuilt using the larger 60 trim compressor which goes with the VLT's larger ARR comp cover . I think I may still have the VL cover and wheel kicking around if you can't find them .
Cheers A .
Cheers  A .
Other option that you can use is to use the compressor wheel off of the 13bt's hitachi, i know a few boys in adelaide have done that, works quiet well apparently...
Shane,
How's your car doing?
You get to use those parts I sent down wisely.
Cheers,
Dennis
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
