Hi all.. this is my first post after a brief time away from the imports.. (been playing on the only thing that comes close to an import for bang for buck thrills..a kwaka ZX9R)..I am about to get back into the scene and am looing at buying a Stagea through J Spec imorts...if anyone has feeback on dealing with them and going through the compliance proccess..it would be of great value.
Looking foward to geting back into the scene and puting a few more Stagea's on the streets of Melbounre ( aint seen one yet)
Cheers
Scott.
https://www.sau.com.au/forums/topic/85828-feedback-on-j-spec-imports-please/
I bought mine from J Spec just recently. Very very good service and a great members area on the website. ;) Would definatly be recommending them. Constantly in touch and organising everything for me. Pluse, I saved $100 bucks by using J Spec as opposed to Prestige ... :P hehehe
I'll think you'll find excellent reports from people who've used Prestige and people who've chosen J-Spec. They are probably the two largest and well known import brokers in Australia, with excellent contacts who can help you along the entire way.
  • 5 months later...
I've read a lot that brokers will 'ASSIST' you along the process. I was under the impression that for the $1000 (or thereabouts) you can sit back and answer questions. I though they were supposed to organise and carry out the entire process, shipping, customs clearance and compliance.
Is this right?
Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
