Looking for rear springs for my R32GTR - want a spring rate of ~250lbs, 60/61mm ID, free height of around 250mm (?) with tender coils.
What's the difference between the three spring manufacturers?
King 'pro sport' coil springs are 'Hot rolled, oil quenched and tempered', whereas Whiteline race springs are 'chrome cold wound'... what's the go with them?
Questions:
1. will i get away with a shorter spring, say 220mm, with using tenders as well
2. two choices will be
Kings - KPS-042 250mm free height, 250lb
Whiteline - CS61220045 220mm free height, 252lb
are they more or less both the same?
3. do lovells make linear rate 60ID springs?
Cheers in advance
https://www.sau.com.au/forums/topic/85845-king-whiteline-lovells-springs/
As always, i recall Sydneykid posted on the subject ages ago, i cant recall the exact differences myself, other then the rate of cooling/quenching affects the grain structure after being heated beyond a metals eutectic point (does it get heated that high???) so requires controlled cooling to stop the grain structure from becoming too martensitic and becoming brittle.
Cold working also has dramas, and requires a steel with slightly different mechanical properties, and cold workign normally hardens the metal...so there is a trade off in there as well when the spring will have very high cyclic loads and likely heat up during operation.
LOL...i bet i have confused martensite with austenite etc...i cant remember that crap. i bet GTR_Geoff or someone else knows it off the tops of their heads though
I will avoid the metallurgy. Whitleine use cold winding spring steel from BHP (to the German Standard) , it is specifically designed for the cold winding of coils and to maintain its grain structure during that process. This requires high powered hydraulic coil winders. This the same basic steel specification as used by Eibach, Jamex, Koni, Bilstein etc This process is good if you are making small batch runs, as the set up time for different coils is short.
Kings, on the other hand, use spring steel, also from BHP, that is designed for hot winding. This requires a much lower powered coil winder, but tempering is an additional step in the process. Many OEM coils are made this way as the process is good for long batch runs, due to the longer (than cold winding) set up time.
The bottom line is, neither process is technically superior as long as the procedures (for that grade of spring steel) are followed.
:rolleyes: cheers :)
Thanks Gary,
My other questions was, is there any problem with going to a shorter spring (from 250 to 220mm) if I am using tender coils and have plenty of threaded shock body to wind the lower spring seats up a bit?
cheers, marcus
Thanks Gary,
cheers, marcus
No, just be aware of the increased potential for coil bind and make sure the bump stops prevent it. Coil springs don't like coil bind.
:D cheers ;)
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
